[PIC] 18F4550 to read Analog value
ycnr
Newbie level 5
Hi, I use 18 F 4550 to read 12 chanels analog values. I couldn't read values from portB. As you see i use PortE and PortB. I can read form PortE (except one pin) but i couldn't read any value from PortB. I tried many ways but i couldn't find the reason. is there anybody to help me.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
#include <18f4550.h>
#device ADC=10
#FUSES INTRC, NOWDT, NOLVP, PBADEN, NOBROWNOUT
#use delay(clock=4Mhz)
#include <lcd420_pc.c>
float inpt,outpt;
main(){
         setup_oscillator(OSC_4MHZ);
         setup_psp(PSP_DISABLED);
         setup_comparator(NC_NC_NC_NC);
         setup_spi(SPI_SS_DISABLED);
         DISABLE_INTERRUPTS(GLOBAL);
         setup_timer_1(T1_DISABLED);
         setup_timer_2(T2_DISABLED,0,1);
         setup_timer_3(T3_DISABLED|T3_DIV_BY_1);
         setup_CCP1(CCP_OFF);
         setup_CCP2(CCP_OFF);
         setup_vref(FALSE);
         setup_adc_ports(ALL_ANALOG);
         setup_adc(ADC_CLOCK_INTERNAL);
         set_tris_a(0xff);
         set_tris_b(0xff);
         set_tris_e(0xff);
         set_tris_c(0x00);
         set_tris_d(0x00);
         lcd_init();
         delay_ms(10);
        while(true){
         kanal_1:
         if(input(PIN_B7)==0) {while(true) {if(input(PIN_B7)==1) goto kanal_2;}}
         if(input(PIN_B6)==0) {while(true) {if(input(PIN_B6)==1) goto kanal_6;}}
         set_adc_channel(6);
         delay_us(10);
         inpt=read_adc()*0.00977517106549364613880742913001;
         output_c(0x00);output_bit(PIN_C0,1);
         set_adc_channel(0);
         delay_us(10);
         outpt=read_adc()*0.02346041055718475073313782991202;
         lcd_gotoxy(1,1); printf(lcd_putc,"1.IN=%3.1f",inpt);
         lcd_gotoxy(1,2); printf(lcd_putc,"1.OT=%3.1f",outpt);
similar codes for each channels
I can´t help with the PIC..
Is the numbering of the ADC channels correct? --> When you select channel6, is this referring to correct port pin?
but some hints, if you don´t mind.
* a capacitor next to the ADC input pins helps to make readings more stable
* a display update every 300ms is enough, so i recommend to use a 300ms dely in your main loop
* It may be a 10 or 12 bit ADC, so you factor 0.00977517106549364613880742913001 won´t make a difference to: 0.009775. Even the precision of a 32 bit float is limited to : 0.009775171
I wonder if the compiler can handle your value.
* The factor values make me think you want a precise measurement. But on the other hand it seems you use VCC as reference. Can you rely on VCC to be that accurate?..with change in load current, temperature, time...
* you should use bulk and decoupling capacitors on VCC, VREF and other importand voltages.
Klaus
Thank you Klaus.
I added capasitor, tried 12 bit ADC. But these can't solve my problem.
