shaun_c_m
Junior Member level 2
hi, is anyone able to talk me through the steps required to change the clock source from an external 10 MHz crystal with PLL (ie 40 MHZ clock) down to the 31 KHz internal clock?
it looked simple until i found out that i had to start up oscilators before i could switch sources, now im a bit confused
thanks in advance
thanks in advance
