12 to 5v Buck Converter (Gate Driver Issue)
armghan11
Member level 1
I am designing a buck converter having specifiaction
Input Voltage = 12v
Output = 5v
Output Current = 1.5A
I am using a IR2110/IR2112 as a gate driver. My proteus simulation is working perfectly but when i implemented it on breadboard the IR2110 didnt worked :( Need Help
I have attached the image of Proteus Simulation Screenshot 2015-01-01 19.06.28.png
The circuit can only start if the output voltage is initially zero and will fail with light load. A possible solution is to replace D1 with a low-side transistor, implementing a synchronous buck converter.
can you give me any schematic example? thanks in advance :)
