any info or links to buck and boost power dc/dc converters
sullybully
Junior Member level 1
Mars
Hello all,
Do i get any info any or links to buck and boost power dc/dc converters ?
Sully
whata coincidence!
try this link.
also with really simple
program for calcs,so easy!!!!!!!
so good a chip LM2576
For the basic principle read ArtOfElectronics. You can build a switcher yourself with PWM output of a PIC for example. But make sure your PIC never crashes :smile:
For good efficiency yet simple to use circuits look up Nationals SIMPLE SWITCHER series.
Buck -> Step-down converter
Boost -> Step-up converter
Buck : mainly PWM control
Boost : PWM,PFM.VFM control
Operation Mode : Continuos / Discontinuos Current Mode( according to inductor current)
Basic Topology -> TEXT BOOK ...
Thanks.
On 2002-03-26 05:36, sullybully wrote:
Hello all,
Sully
who can send me some MCU control DC-DC sch
hi all.
I want to know theoretical and practical m@x response frequency of dc/dc converters, and which componets make the m@x response frequency limits?
thanks.
you can use the mentor analog designer to sim
you design.use it,you can find frequency response.
Re: Buck and boost
see
Re: Buck and boost
look at this link, a premier:
Re: Buck and boost
It is basic topology for dc-dc,i think you use google,you will find several huandreds imformation about it.
Ti,Maxim,Fairchild,national,All have applications about it.
Buck and boost
read the book "power electronics handbook"
upload already.
Buck and boost
Basic book:
Power Electronics: Erickson.
See site from Power Electronics Colorado Center.
Re: Buck and boost
In these days I am studying the documentation in reference to the argument. I pass to you what I have found!
Hi
Attrix
Re: Buck and boost
Is there any design/chip capable of auto-switching from step-up to step down (&vice versa) by detecting the voltage output ?
P.S. I don't want to have inverted output => CUK converter is not preferred.
Any idea?
Re: Buck and boost
HI,
If you want to spend little motorola proposes with a MC34063 a good application step-up/down that it works!
  • an920-d_111.pdf
Re: Buck and boost
SEPIC converters will do either Buck or Boost without inversion.
Re: Buck and boost
Any idea?
Linear Technology, LTC3441 can do that function
