+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 4
    Points: 2,935, Level: 12
    Join Date
    May 2004
    Posts
    227
    Points
    2,935
    Level
    12
    vhdl addition
    Hi Guys
    Can anyone pls tell me how to do binary addition with vectors...
    i tried to do but it gives me a error as "Type error resolving infix expression "+" as type std_logic_vector."
    [syntax=vhdl]
    Library IEEE;
    Use Ieee.std_logic_1164.all;
    entity add is
    Port(
    a: in std_logic_vector(3 downto 0) ;
    sum:out std_logic_vector(3 downto 0)
    end add;
    architecture behav of add is
    signal tmp : std_logic_vector(3 downto 0);
    begin
    tmp <= a(0) + a(1) +a(2) + a(3) when en = '1' else "0000";
    sum <= tmp;
    end behav;[/syntax]
    Last edited by andre_teprom; 4th March 2014 at 02:20. Reason: added VHDL syntax formatting
    •   Alt22nd November 2006, 05:25
      advertising
  2. #2
    Junior Member level 1
    Points: 1,700, Level: 9
    Join Date
    May 2004
    Ukraine-> S.Korea
    Posts
    18
    Points
    1,700
    Level
    9
    addition in vhdl
    Hi!
    Just add:
    1. Use Ieee.std_logic_unsigned.all;
    2. en: in std_logic;
    3. you have to extend a(0), a(1) etc to 4bit by "000"&
    Have a nice day!
    Library IEEE;
    entity add is
    Port(
    en: in std_logic;
    end add;
    begin
    tmp <= (("000"&a(0)) + ("000"&a(1))+ ("000"&a(2)) + ("000"&a(3))) when en = '1' else "0000";
    sum <= tmp;
    end behav;
    [/code]
  3. #3
    Full Member level 4
    Join Date
    May 2004
    Posts
    227
    Points
    2,935
    Level
    12
    vhdl std_logic_vector addition
    Quote Originally Posted by dunets
    Hi!
    Just add:
    Have a nice day!
    Library IEEE;
    entity add is
    Port(
    en: in std_logic;
    end add;
    begin
    sum <= tmp;
    end behav;
    [/code]
    Hi Dunets
    Thanks a lot for your help.
    tama
    •   Alt22nd November 2006, 10:51
      advertising
  4. #4
    Newbie level 5
    Points: 1,140, Level: 7
    Join Date
    Nov 2006
    Posts
    9
    Points
    1,140
    Level
    7
    vhdl binary addition
    Quote Originally Posted by s3034585
    Hi Guys
    Library IEEE;
    entity add is
    Port(
    end add;
    begin
    sum <= tmp;
    end behav;
    include the foolowing libraries
    arith and unsigned too then they will executed
  5. #5
    Full Member level 2
    Points: 2,031, Level: 10
    Join Date
    Mar 2005
    Posts
    129
    Points
    2,031
    Level
    10
    addition vhdl
    i prefer the numeric lib instead of arth lib, the latter is synopsys prepoerity.
  6. #6
    Points: 146, Level: 1
    Join Date
    Mar 2014
    Posts
    16
    Points
    146
    Level
    Re: how to go Binary addition in vhdl with vectors
    can someone please explain to me what this does ("0000"&a(0)) in this particular line of text below. the exact code is in one of the replies on this thread
    sum <= tmp;
    •   Alt2nd March 2014, 08:44
      advertising
  7. #7
    Advanced Member level 5
    Points: 35,434, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,434
    Level
    45
    It creates a vector. a(0) is a single bit. Only vectors of type signed or unsigned can be added together.
  8. #8
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    The code calculates the number of '1' bits in input vector a. Is this what you want to achieve?
    The question title might suggest that you want to add multiple vectors. But there's only one input vector.
