Problem with writing to code memory of PIC16F84
Medtronic
Full Member level 5
Egypt
hi all
please can any one help me to write to pic16f84 code memory,i sucess to read from that memory by my own software and hardware but fail to write to
thanks too much
Re: microcontroller help
elsalam alykom,
i want to know what do u mean?
but as i guess u should have the MPLAB software as an IDE ,and the ICPROG which takes the hex file and download it to the PIC 16F84.
a good hardware programmer for this is JDM do it on PCB it will work good.
illustrate what u want clearly ,and i am in help.
thanks alot
Hi
please say exactly your problem.I think you mean that you can read the program in PIC with your programmer but you can not write any program to PIC.is not it?
if yes first carefully check your programmer pin second check that your pic pins be true.the pins RB6 and RB7 are the pins for read & write with changing them to 0 or 1.check that these two pins are true.
good luck.
hi my frinds
look ,first of all i design my own software and hardware not (ICPROG or etc)
i'm sure that my hardware is good cause it can read from pic16f84
but the problem is to write to code memory
elsalam alykom,
ok i understood u made ur own software which does the function of ICPROG
i think it's better to search to an open source program ,or u can ask the computer
and software members.
if i reached to any thing i will tell u.
thanks alot
