FREE, EASY CODE WRITING For MPLAB Users.(New Ver.)
gidimiz
Advanced Member level 1
easycode tech
This is Ver. 1.0.0.4.
Attached you will find the latest file of the SVH.
You can run it on your computer and check out the features.
The features that are added with this version are:
1. Full support of window lists ( you can switch between open windows by pressing buttons ). See attached image001.jpg
3. Parsing and displaying variables of unnamed structure/union.
Enjoy.
hai
How to install this into MPLAB?
Will it work for assembler also ? I havre tried with hi tech C also
Nothing working.MPLAB detected by the programe ,But no effects,
Any help?
Picstudent
Its not working with .asm.
With any ANSI C its working well. after you start MPLAB then open the SVH and see that it has detected the MPLAB 7.XX. then open the project and one of the .c files. write some code and see how it works.
Good luck.
Good luck.
I have tried exactly as you said in MPLAB with Hi tech C.
SVH detected MPLAB 7.2 as you said.
But nothing changed with the appearence of sourse file window.
My OS is windows 2000Pro.I have tried in winXP also.
Nothing works here
Picstudent
If SVH detected MPLAB then it attached successfully.
Open .C file and press Ctrl+Space for view Item-list or Ctrl+Shift+Space for view details of selected item
Best regards
Added after 5 minutes:
It works on Win9x and WinNT (WinXP inclusive)
Enjoy.
That is great stuff!
Could you just explain please what you mean by those two?
