+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 3
    Points: 2,631, Level: 11
    Join Date
    Dec 2004
    Posts
    58
    Points
    2,631
    Level
    11
    verilog z
    is it illegal to use 'z' value in expression, in synthesis point of view?
    and in any form inside a clocked always block?
    •   Alt7th June 2005, 15:45
      advertising
  2. #2
    Full Member level 3
    Points: 2,648, Level: 11
    semiconductorman's Avatar
    Join Date
    Dec 2004
    Posts
    156
    Points
    2,648
    Level
    11
    z in verilog
    Not entirely true ... U can synthesise 'casez ' to produce a priority mux structure . Z indicates undriven state so don't make any calculations based on these ..
    •   Alt8th June 2005, 08:29
      advertising
  3. #3
    Banned
    Points: 1,995, Level: 10
    Join Date
    Feb 2005
    INDIA
    Posts
    97
    Points
    1,995
    Level
    10
    verilog z value
    if u have a Z state in mux it will not work.....
    •   Alt8th June 2005, 11:18
      advertising
  4. #4
    Full Member level 6
    Points: 2,793, Level: 12
    Join Date
    Jun 2005
    Posts
    373
    Points
    2,793
    Level
    12
    z verilog
    Z should not be used in internal logic,
    because internal tri state gate can increase chip's power consumption and
    increase difficulty to DFT. Z only can be used on top IO ports.
    Quote Originally Posted by Prasanna Kumar
  5. #5
    Advanced Member level 3
    Points: 16,682, Level: 31
    Join Date
    May 2001
    Posts
    996
    Points
    16,682
    Level
    31
    verillog equating z
    Hi
    What about U (Un-initialized) value of VHDL when converting to verilog.
    I have some troubles with VHDL files with 'U' when converting to Verilog.
    Does someone have a solution?
    tnx
