+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 30
  1. #1
    Junior Member level 3
    Points: 1,690, Level: 9
    Join Date
    Dec 2004
    Posts
    30
    Points
    1,690
    Level
    9
    How can I describe a ROM in VHDL?
    hi :
    all guys. I wanna discribe a ROM in VHDL , but VHDL is very new to me. And my this ROM is designed to store sine wave table. Can someone help me?
    Any help would be appreciate!
    •   Alt11th May 2005, 03:46
      advertising
  2. #2
    Advanced Member level 3
    Points: 9,432, Level: 23
    Join Date
    Jul 2004
    Posts
    892
    Points
    9,432
    Level
    23
    rom vhdl
    Here is a basic code for ROM in VHDL!
    Hope this helps.
    library ieee;
    use ieee.std_logic_1164.all;
    entity ROM is
      port ( address : in std_logic_vector(3 downto 0);
             data : out std_logic_vector(7 downto 0) );
    end entity ROM;
    architecture behavioral of ROM is
      type mem is array ( 0 to 2**4 - 1) of std_logic_vector(7 downto 0);
      constant my_Rom : mem := (
        0  => "00000000",
        1  => "00000001",
        2  => "00000010",
        3  => "00000011",
        4  => "00000100",
        5  => "11110000",
        6  => "11110000",
        7  => "11110000",
        8  => "11110000",
        9  => "11110000",
        10 => "11110000",
        11 => "11110000",
        12 => "11110000",
        13 => "11110000",
        14 => "11110000",
        15 => "11110000");
    begin
       process (address)
       begin
         case address is
           when "0000" => data <= my_rom(0);
           when "0001" => data <= my_rom(1);
           when "0010" => data <= my_rom(2);
           when "0011" => data <= my_rom(3);
           when "0100" => data <= my_rom(4);
           when "0101" => data <= my_rom(5);
           when "0110" => data <= my_rom(6);
           when "0111" => data <= my_rom(7);
           when "1000" => data <= my_rom(8);
           when "1001" => data <= my_rom(9);
           when "1010" => data <= my_rom(10);
           when "1011" => data <= my_rom(11);
           when "1100" => data <= my_rom(12);
           when "1101" => data <= my_rom(13);
           when "1110" => data <= my_rom(14);
           when "1111" => data <= my_rom(15);
           when others => data <= "00000000";
    	 end case;
      end process;
    end architecture behavioral;
    3 members found this post helpful.
  3. #3
    Join Date
    Dec 2004
    Posts
    30
    Points
    1,690
    Level
    9
    rom vhdl code
    thanks for replies
    The ROM I wanna describe is too large .
    Is there any method else?
  4. #4
    Full Member level 3
    Points: 3,235, Level: 13
    Join Date
    Jan 2005
    India
    Posts
    173
    Points
    3,235
    Level
    13
    rom en vhdl
    Hi skycanny,
    i feel u r trying to generate a direct digit synthesizer or a sine wave generator.
    which is ur target device?
    if u r using xilinx tools, then it's easy to generate the rom and dds using xilinx ise tool.
    Coregen will automatically generate the rom which u need to generate the sine, depending upon the output sine frequency and step resolution.
    1 members found this post helpful.
  5. #5
    Join Date
    Dec 2004
    Posts
    30
    Points
    1,690
    Level
    9
    vhdl code rom
    hi,Renjith:
    You are right
    I am trying to implement a DDS and using Xilinx FPGA.
    However, I do not want to use CoreGen because the module CoreGen creates is hard to migrate to other target device.
    Could you help me?
  6. #6
    Member level 5
    Points: 2,179, Level: 10
    Join Date
    Jul 2003
    Portugal
    Posts
    88
    Points
    2,179
    Level
    10
    vhdl rom model
    You can use a RAM of a FPGA inittialized with the content that you want (look at the Xilinx FPGAs BRAMs manual for instance). You just must take care that there aren't any writes to the RAM. The beautie of this is that you can easly initialize the RAM without the need to code a look-up table. The disavantage is that you waste BRAMs of the FPGA but you don't waste logic resources.
  7. #7
    Member level 5
    Points: 2,831, Level: 12
    maxer's Avatar
    Join Date
    May 2001
    Posts
    86
    Points
    2,831
    Level
    12
    rom in vhdl
    use "BlockRam" devices in case you plan to use xilinx devices or LPM library if you plan to use Altera ones...
    both of them are very efficient.
    You can treat BlockRam as a Rom Memory by disabling the RW line.
    regards
    maXer
  8. #8
    Member level 1
    Points: 1,653, Level: 9
    Join Date
    Jan 2005
    UK
    Posts
    38
    Points
    1,653
    Level
    9
    dds vhdl
    I agree with nand_gates
    I think that the best way to put RAM into an FPGA is by using a two dimensional array.
    This is the way that I have done it on many occasions and it’s always been successful.
    If I wanted to describe a large memory
    (Which I haven’t in the past because it’s often easier/less expensive, just to attach some RAM to the FPGA, but I understand that this may not be true in your case, pin count, start case and so on).
    I would use the method described by nand_gates and try to extend this idea using something like the “generate” statement.
    Hope that helps
    Kind Regards Bob
  9. #9
    Full Member level 3
    Join Date
    Jan 2005
    India
    Posts
    173
    Points
    3,235
    Level
    13
    vhdl rom code
    Quote Originally Posted by skycanny
    hi,Renjith:
    ok... r u trying to target to some other xilinx family or non-xilinx families or an ASIC prototype.
    if it's other xilinx families itself, then coregen is a solution for u.
    if the target is a non-xilinx family, then u r right,
    as u cannot port coregen modules to that.
    so what i cud guess is, u want to generate a generic vhdl model of DDS.
    in that case,u have to store the sine coeffiecients in the rom manually,
    as nandgates suggested.
    Again, u can use ur coregen tool to generate the sine coeffiencts,
    when u r generating a DDS model thrg Coregen, then it automatically creates a .mif file, which has all the coefficients inside as per ur spec.
    u have to take this and put it in your vhdl code, no matter which ever ur target is.
    •   Alt11th May 2005, 13:13
      advertising
  10. #10
    Newbie level 1
    Points: 1,369, Level: 8
    Join Date
    May 2005
    Posts
    Points
    1,369
    Level
    8
    vhdl rom example
    i also suggest the generate command. It is useful for a large number of similar devices one has to write code for. If you are newbie, just refer to the VHDL manual about generate command. Using Xilinx ISE is the fast way but anyway you should know VHDL code.
    •   Alt11th May 2005, 15:17
      advertising
  11. #11
    Join Date
    Dec 2004
    Posts
    30
    Points
    1,690
    Level
    9
    vhdl code for rom
    thank all guys
  12. #12
    Full Member level 1
    Points: 2,341, Level: 11
    Join Date
    Mar 2005
    Taiwan
    Posts
    96
    Points
    2,341
    Level
    11
    vhdl ram data initialization rom
    Hi skycanny,
    You can use a high level language to do the job.
    By using the "fprint" like function(fprint is a C funtion) to print out the rom content and other words(as nand_gates's code) to a single file. This code is portable.
    I do the similar job by using Matlab.
    Regard,
    Jarod
  13. #13
    Join Date
    Dec 2004
    Posts
    30
    Points
    1,690
    Level
    9
    rom+vhdl
    Hi,jarodz:
    thank you
    I have done it by Matlab and added it to code
  14. #14
    Member level 1
    Points: 1,760, Level: 9
    Join Date
    Dec 2004
    Shanghai, China
    Posts
    41
    Points
    1,760
    Level
    9
    vhdl+rom
    Matlab or C is a good choice.
  15. #15
    Newbie level 5
    Points: 715, Level: 5
    Join Date
    Mar 2009
    Posts
    8
    Points
    715
    Level
    vhdl coding for rom
    hey...i created a rom this way
    library ieee;
    entity ROM is
      port ( clk : in std_logic;
    			e : in std_logic;
    			r : in std_logic;
    end entity ROM;
    signal i: integer range 0 to 6063:=0;
    signal enable : STD_LOGIC:='0';
    type mem is array ( 0 to 6063) of std_logic_vector(7 downto 0);
    DATA HERE...
    since i have to put inside it a large code, almost 10000 8bit packets, i created a script in matlab (using fprintf) that generated the data i need to put in file.
    my problem now is that when synthetizing in ise, this takes almost 40 minutes to complete.
    coregen isnt a solution for me since we are not allowed to use it...
    i hope anyone could give me a hand with this
    thanks
  16. #16
    Full Member level 4
    Points: 2,726, Level: 12
    Join Date
    Mar 2008
    europe
    Posts
    208
    Points
    2,726
    Level
    12
    text file rom vhdl
    Quote Originally Posted by moreins
    /.../problem now is that when synthetizing in ise,
    this takes almost 40 minutes/.../
    you've created a large constant, not a ROM block,
    that's why the compiler needs so much time to connect
    inputs of logic cells to "1's" and "0's" accordingly
    to your description;
    the tool should recognize the ROM if you write it somehow
    like in an example below:
    process(clk)
       begin
          if(rising_edge(clk)) then
          q <= my_Rom(addr);  <=======
          end if;
    end process;
  17. #17
    Newbie level 5
    Join Date
    Mar 2009
    Posts
    8
    Points
    715
    Level
    ram and rom in vhdl
    hello
    thanks for you reply
    this is the complete code that i sinthetized last night. it took about 40 minutes.
    library ieee;
    entity ROM is
    			e : in std_logic;
    			r : in std_logic;
    end entity ROM;
    "10000011",
    "10000100",
    "10000101",
    "10000011",
    ....7000 more lines
    begin
    process(e)
    begin
    if e'event and e='1' then
    enable<='1';
    end if;
    end process;
    process(clk)
    begin
    if r = '1' then
    		data <="00000000";
    elsif enable='1' then
    	if clk'event and clk='1' then
    		data<=my_rom(i);
    		i<=i+1;
    	end if;
    end if;
    end process;
    i didnt post before the end of my code. here it is. maybe thats what youre trying to say with the example you gave me...
    hope you can help me
    thanks
  18. #18
    Full Member level 4
    Join Date
    Mar 2008
    europe
    Posts
    208
    Points
    2,726
    Level
    12
    rom using vhdl coding
    first - change the i range in your file to 7-0,
    compile and carefully read compilation's messages;
    look at the schematics and resource usage report;
    I'm not experienced in vhdl, but even if the example
    below is not perfect it should create a rom memory,
    and give you a hint how it should be done;
    I think it's better to keep a memory content values
    in a seperate text file then in the RTL code;
    how to do it ypu have to find out yourself in the
    ise manual/handbook;
    entity rom is
    port
         clk     : in std_logic;
         e       : in std_logic;
         r       : in std_logic;
         data_out: out std_logic_vector (7 downto 0)
    end rom;
    architecture rtl of rom is
    signal i      : integer range 0 to 7:=0;  -- change the range value
    signal enable : std_logic:='0';
    signal data   : std_logic_vector (7 downto 0);
    BEGIN
      process (e) -- i don't like this, would be better
      begin       -- to use clk as a sync. signal
         if e'event and e = '1' then
           enable <= '1';
         end if;
      end process;
      process ( clk)
      begin
        if rising_edge (clk) then
           if (enable = '1')   then
             i <= i + 1;
           end if;
        end if;
      end process;
      process (clk)
      begin
          case  i is
            when  0  => data <= "10111100";
            when  1  => data <= "11011001";
            when  2  => data <= "00000111";
            when  3  => data <= "10101000";
            when  4  => data <= "10101001";
            when  5  => data <= "10101000";
            when  6  => data <= "10101011";
            when  7  => data <= "10110010";
            -- ....    fill in the correct values here for larger 'i' index
          end case;
        end if;
      end process;
      process (r,data)
      begin
        if r = '1' then  data_out <= "00000000";
        else             data_out <= data;
        end if;
      end process;
    END rtl;
  19. #19
    Newbie level 5
    Points: 1,057, Level: 7
    Join Date
    Jun 2007
    Posts
    9
    Points
    1,057
    Level
    7
    dds vhdls
    you can use quartus LMP ROM, it very easy. if you cann't do it yourself, tell me>
  20. #20
    Super Moderator
    Points: 241,624, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,962
    Points
    241,624
    Level
    100
    rom coding in vhdl
    The rules for ROM inference from HDL code are tool dependant. As you are apparently using Xilinx, you should check the respective software handbooks. In addition, the ROM structure must be representable by the existing device hardware in terms of required address and/or data output latches.
    A typical reason, why ROM or RAM inference fails is to include a logic feature, that isn't available in the hardware. I guess, this is the case with the r='1' condition in your design. You may want to remove this condition and also the enable signal first. Most likely, an auxilary register between the ROM and the output port is required to allow ROM inference in this case.
    if r = '1' then
          data <="00000000";
          data<=my_rom(i);
          i<=i+1;
       end if;
    end if;
    I append an Altera Quartus ROM template for reference. Please pay attention to the structure of the output process, that has no additional conditions. It may work with Xilinx as well.
    library ieee;
    use ieee.numeric_std.all;
    entity single_port_rom is
    	generic
    		DATA_WIDTH : natural := 8;
    		ADDR_WIDTH : natural := 8
    	port
    		clk		: in std_logic;
    		addr	: in natural range 0 to 2**ADDR_WIDTH - 1;
    		q		: out std_logic_vector((DATA_WIDTH -1) downto 0)
    end entity;
    architecture rtl of single_port_rom is
    	-- Build a 2-D array type for the RoM
    	subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0);
    	type memory_t is array(2**ADDR_WIDTH-1 downto 0) of word_t;
    	function init_rom
    		return memory_t is
    		variable tmp : memory_t := (others => (others => '0'));
    	begin
    		for addr_pos in 0 to 2**ADDR_WIDTH - 1 loop
    			-- Initialize each address with the address itself
    			tmp(addr_pos) := std_logic_vector(to_unsigned(addr_pos, DATA_WIDTH));
    		end loop;
    		return tmp;
    	end init_rom;
    	-- Declare the ROM signal and specify a default value.	Quartus II
    	-- will create a memory initialization file (.mif) based on the
    	-- default value.
    	signal rom : memory_t := init_rom;
    begin
    	process(clk)
    	begin
    		q <= rom(addr);
    	end if;
    	end process;
    end rtl;
    •   Alt10th April 2009, 07:13
      advertising
