LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY FIFO_tb IS
END FIFO_tb;
ARCHITECTURE behavior OF FIFO_tb IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT Asynch_FIFO
PORT(
rst : IN std_logic;
wr_clk : IN std_logic;
rd_clk : IN std_logic;
din : IN std_logic_vector(7 downto 0);
wr_en : IN std_logic;
rd_en : IN std_logic;
dout : OUT std_logic_vector(7 downto 0);
full : OUT std_logic;
empty : OUT std_logic;
rd_data_count : OUT std_logic_vector(7 downto 0);
wr_data_count : OUT std_logic_vector(7 downto 0)
END COMPONENT;
--Inputs
signal rst : std_logic := '0';
signal wr_clk : std_logic := '0';
signal rd_clk : std_logic := '0';
signal din : std_logic_vector(7 downto 0) := (others => '0');
signal wr_en : std_logic := '0';
signal rd_en : std_logic := '0';
--Outputs
signal dout : std_logic_vector(7 downto 0);
signal full : std_logic;
signal empty : std_logic;
signal rd_data_count : std_logic_vector(7 downto 0);
signal wr_data_count : std_logic_vector(7 downto 0);
-- Clock period definitions
constant wr_clk_period : time := 10 ns;
constant rd_clk_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: Asynch_FIFO PORT MAP (
rst => rst,
wr_clk => wr_clk,
rd_clk => rd_clk,
din => din,
wr_en => wr_en,
rd_en => rd_en,
dout => dout,
full => full,
empty => empty,
rd_data_count => rd_data_count,
wr_data_count => wr_data_count
-- Clock process definitions
wr_clk_process :process
begin
wr_clk <= '0';
wait for wr_clk_period/2;
wr_clk <= '1';
end process;
rd_clk_process :process
begin
rd_clk <= '0';
wait for rd_clk_period/2;
rd_clk <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
RST <= '1';
wait for Wr_clk_period;
RST <= '0';
for i in 0 to 255 loop
Wr_en <= '1';
din <= din + 1;
end loop;
Wr_en <= '0';
Rd_en <= '1';
wait for Rd_clk_period;
end loop;
-- insert stimulus here
wait;
end process;
END;
In short: don't read if FIFO is empty.
You are correct from the view if the FIFO, but the "reader" can't be sure if the data is valid or not.
And for the simulation: if there are RD and WR edges at the same time on an empty device you can't verify the function of the FIFO.
--> operate the FIFO according it's specifications.
