WEH
Newbie level 1
Hello,
This is my first time to use Verilog A to design a model in Cadence Spectre. I aim to use a controllable current source to model an AC load with given active power P and reactive power Q. At the end of each period, i.e., 1/fc, the current of the current source is updated based on the active power P, reactive power Q, and the voltage amplitude Vamp and phase Vphi during the past period. Below is my verilog A code and it can not pass the compilation when I try to create a symbol from these codes. The error information is also attached. Could anyone help me figure out how to fix these codes? Thank you.
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 // VerilogA for power_grid_simulation, load_cpq, veriloga `include "constants.vams" `include "disciplines.vams" module load_cpq(vin); input vin; electrical vin; parameter real fc=50.0; parameter real P=0.9; parameter real Q=0.3; real Amax= -10**9; real Amin = 10**9; real Vamp = 1.0; real Vphi = 0; real Iamp = 2*sqrt(P*P+Q*Q)/Vamp; real Iphi = Vphi-atan(Q/P); real vin_value; integer sample_per_cycle = 100; always #(1/(sample_per_cycle*fc)) begin vin_value=V(vin); if ($realtime()%(1/fc)) begin Vamp =(Amax-Amin)/2; Vphi = acos(V(vin)/Vamp); Iamp = 2*sqrt(P*P+Q*Q)/Vamp; Iphi = Vphi-atan(Q/P); Amax = -10**9; Amin = 10**9; end else begin Amax=(vin_value>Amax)?vin_value:Amax; Amin=(vin_value<Amin)?vin_value:Amin; end end analog begin I(vin) <+ Iamp*cos(2.0*`M_PI*fc*$realtime()+Iphi); end endmodule
Warning from spectre during AHDL compile.
WARNING (VACOMP-1086):
"/space3/DRV3/home/whan/power_grid_simulation/load_cpq/veriloga/veriloga.va",
line 23: `always' is not a reserved keyword now but will be one in a
future release. Parsing `always' as an identifier for now.
Error found by spectre during AHDL compile.
ERROR (VACOMP-2163): "always #(1/(sample_per_cycle*fc))<<--? "
line 23: Encountered ordered parameter override lists. The software
does not support this feature. Use named lists instead.
ERROR (VACOMP-2259): "begin<<--? "
line 24: syntax error.
ERROR (VACOMP-1814): Maximum allowable errors exceeded. Exiting AHDL
compilation....
