Signal declaration based on a generic + VHDL
dpaul
Advanced Member level 5
Germany
I have a generic of type standard logic passed down from top-level to module level.
Based on a '1' value of that generic, I want declare a certain set of signals. If the generic value is '0', I want to declared another set of signals.
I think I cannot use generate.
What is the best way to do it?
IDE - Vivado 2017.2
Regards.
Update> Thinking about an alternative like....is it the best approach?
entity my_entity is
    generic(
        GENERIC_VAL : std_logic := '0'
    port (
end my_entity;
architecture my_entity_arc of my_entity is
signal a : std_logic; --
signal b : std_logic; --
signal c : std_logic; -- common signal
begin
    use_gen : if GENERIC_VAL='0' generate
        c <= a;
    else generate
        c <= b;
    end generate use_gen;
end my_entity_arc;
Signals cannot be declared conditionally, only assigned to different things. So your attempted approach may be the only option.
You can declare signals locally inside a generate, if that helps, though they are not visible outside of the generate:
my_gen : if something generate
  signal local_generate_signal : std_logic;
begin
  c <= local_generate_signal;
end generate my_gen;
Reactions: dpaul
    dpaul
You can declare signals locally inside a generate, if that helps, though they are not visible outside of the generate.
Thanks, never used this, was new to me.
I will implement the approach in #1.
