+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 4
    Points: 1,224, Level: 7
    Join Date
    Feb 2016
    Posts
    209
    Points
    1,224
    Level
    7
    Round Robin systemverilog code question
    I have a question regarding round robin systemverilog source code.
    What are the purposes of lines 49 and 54 of https://www.edaplayground.com/x/2TzD
    // Copyright 2011-2015 Jeff Bush
    // Licensed under the Apache License, Version 2.0 (the "License");
    // you may not use this file except in compliance with the License.
    // You may obtain a copy of the License at
    //     http://www.apache.org/licenses/LICENSE-2.0
    // Unless required by applicable law or agreed to in writing, software
    // distributed under the License is distributed on an "AS IS" BASIS,
    // WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
    // See the License for the specific language governing permissions and
    // limitations under the License.
    // Round robin arbiter
    // Units that want to access a shared resource assert their bit in the 'request'
    // bitmap. The arbiter picks a unit and sets the appropriate bit in the one hot
    // signal grant_oh. This does not register grant_oh, which is valid the same
    // cycle as the request. The update_lru signal indicates the granted unit has
    // used the resource and should not receive access again until other requestors
    // have had a turn.
    module rr_arbiter
        #(parameter NUM_REQUESTERS = 4)
        (input                              clk,
        input                               reset,
        input[NUM_REQUESTERS - 1:0]         request,
        input                               update_lru,
        output logic[NUM_REQUESTERS - 1:0]  grant_oh);
        logic[NUM_REQUESTERS - 1:0] priority_oh_nxt;
        logic[NUM_REQUESTERS - 1:0] priority_oh;
        localparam BIT_IDX_WIDTH = $clog2(NUM_REQUESTERS);
        always_comb
        begin
            for (int grant_idx = 0; grant_idx < NUM_REQUESTERS; grant_idx++)
            begin
                grant_oh[grant_idx] = 0;
                for (int priority_idx = 0; priority_idx < NUM_REQUESTERS; priority_idx++)
                begin
                    logic is_granted;
                    is_granted = request[grant_idx] & priority_oh[priority_idx];
                    for (logic[BIT_IDX_WIDTH - 1:0] bit_idx = priority_idx[BIT_IDX_WIDTH - 1:0];
                        bit_idx != grant_idx[BIT_IDX_WIDTH - 1:0]; bit_idx++)
                    begin
                        is_granted &= !request[bit_idx];
                        $display("grant_idx = %1d, priority_idx = %1d, bit_idx = %1d, is_granted = %1b", grant_idx, priority_idx, bit_idx, is_granted);
                    end
                    grant_oh[grant_idx] |= is_granted;
                end
            end
        end
        // rotate left
        assign priority_oh_nxt = {grant_oh[NUM_REQUESTERS - 2:0],
            grant_oh[NUM_REQUESTERS - 1]};
        always_ff @(posedge clk, posedge reset)
        begin
            if (reset)
                priority_oh <= 1;
            else if (request != 0 && update_lru)
            begin
                assert($onehot0(priority_oh_nxt));
                priority_oh <= priority_oh_nxt;
            end
        end
    endmodule
    [syntax=verilog][/syntax]
    •   Alt14th March 2017, 14:45
      advertising
  2. #2
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Re: Round Robin systemverilog code question
    At a glance (without trying to simulate it at all), I think this is what is going on.
    The grants are based on the requests that are active (the request array) and the priority being non-0. The indices select which requester to look at.
    This clears the grant based on the request serviced.
    It would probably be easier and certainly more educational for you to run a simulation with various scenarios of requests and observe the changes in the signals.
