What is the benefit of using virtual in systemverilog?
u24c02
Advanced Member level 1
What is the benefit of using polymorphism in systemverilog?
I'd like to know "practically" the benefit of virtual used in systemverilog.
Here is simple example,
   program main();
    class A;
    virtual task disp();
    $display("This is a A class");
    endtask
    class A_1 extend A;
    task disp();
    $display("This is a A_1 class");
    endtask
    endclass
    class A_2 extend A;
    task disp();
    $display("This is a A_2 class");
    endtask
    endclass
    class A_3 extend A;
    task disp();
    $display("This is a A_3 class");
    endtask
    endclass
    A a;
    A_1 a_1;
    A_2 a_2;
    A_3 a_3;
    initial begin
    a = new();
    a_1 = new();
    a_2 = new();
    a_3 = new();
    a.disp();
    a = a_1;
    a.disp();
    a = a_2;
    a.disp();
    a = a_3;
    a.disp();
    end
    endprogram
As I understand from here, virtual is just can make overriding to another function. and If I want to use polymorphism then I have to use the 'virtual'.
BTW, I can't find any other benefits that using the polymorphism
Does anyone let me know what is the benefit of using the polymorphism ?
Its not as simple as that.
Making a task virtual means that the version at the bottom of the class heirarchy gets called. If a task isnt virtual, it calls the one in the parent class. It only needs to be declared virtual once, at the top of the heirarchy.
In adition, it means you could define some behaviour in A.disp() that is common to all classes, which you call in the child classes:
class A_3 extend A;
    task disp();
      super.disp();  //do something common to all classes
    endtask
endclass
By default the new() function is virtual, and all calls to new() always call super.new() before any other code in the constructor is executed.
