why this block ram vhdl code inffer additional dff?
milan.km
Member level 3
hi
i wrote the following code for makin a block ram,but as my input is 32 bit width,32 DFFs inferred too,
is this sth wrong with my code?
single port block ram
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity spbram is
 generic ( w : integer := 32;
             -- number of bits per RAM word
            r : integer := 12);
             -- 2^r = number of words in RAM
  port (clk  : in std_logic;
        we   : in std_logic;
        adr    : in std_logic_vector(r-1 downto 0);
        di   : in std_logic_vector(w-1 downto 0);
        do  : out std_logic_vector(w-1 downto 0));
end spbram;
architecture spbram_arch of spbram is
  type ram_type is array (2**r-1 downto 0) of std_logic_vector (w-1 downto 0);
  signal RAM : ram_type;
begin
  process (clk)
  begin
    if (clk'event and clk = '1') then
      if (we = '1') then
        RAM(conv_integer(unsigned(adr))) <= di;
      end if;
     do <= RAM(conv_integer(unsigned(adr)));
    end if;
  end process;
 end spbram_arch;
  process (clk)
  begin
      if (we = '1') then
      end if;
     [COLOR="#FF0000"]do <= RAM(conv_integer(unsigned(adr)));	[/COLOR]
    end if;
  end process;
Infers DFFs at the output.
removing the other statements for writing to improve visibility of the problem.
Code VHDL - [expand]
process (clk)
  begin
     do <= RAM(conv_integer(unsigned(adr)));.
    end if;
  end process;
assign the output do outside the process right now it's within the if rising_edge(clk) then (which you should be using instead of 'event stuff).
thanks ads-ee for answering
if I assign the output do outside the process the synthesizer will use distributed ram instead of block ram
i change the code like this but it inffered 32 bit register
library ieee;
entity spbram is
            r : integer := 12);
        we   : in std_logic;
        en   : in std_logic;
        addr    : in std_logic_vector(r-1 downto 0);
end spbram;
begin
  process (clk)
  begin
      if (en = '1') then
        do <= RAM(conv_integer(unsigned(addr)));
        if (we = '1') then
           RAM(conv_integer(unsigned(addr))) <= di;
        end if;
      end if;
    end if;
  end process;
 end spbram_arch;
i use spartan 6 as my hardware and i found the following block diagram in spartan 6 bram resources,
This is taken from the whitepaper. It's kind of old but Xilinx hasn't changed the inference of BRAM since then AFAIK.
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
-- 'write first' or transparent mode
process (clk)
begin
if (rising_edge(clk)) then
if (we = '1') then
 mem(conv_integer(addr)) <= di ;
 do <= di;
else
 do <= mem(conv_integer(addr));
end if;
end if;
end process;
-- 'read first' or read before write(slower)
process (clk)
begin
if (we = '1') then
mem(conv_integer(addr)) <= di;
end if;
end if;
end process;
-- 'no change' mode
process (clk)
begin
if (we = '1') then
else
end if;
end if;
end process;
XST user guide shows this code but it looks like what you wrote.
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
Single-Port RAM in Read-First Mode VHDL Coding Example One
-- Read-First Mode
library ieee;
entity rams_01 is
we : in std_logic;
en : in std_logic;
addr : in std_logic_vector(5 downto 0);
di : in std_logic_vector(15 downto 0);
do : out std_logic_vector(15 downto 0));
end rams_01;
architecture syn of rams_01 is
type ram_type is array (63 downto 0) of std_logic_vector (15 downto 0);
signal RAM: ram_type;
begin
process (clk)
begin
if clk’event and clk =1then
if en =1then
if we =1then
RAM(conv_integer(addr)) <= di;
end if;
do <= RAM(conv_integer(addr)) ;
end if;
end if;
end process;
end syn;
Is the view you are using the post par schematic? Have you checked with a placed and routed design to see if MAP used the internal register?
i change it to no change mode as u write but it still has 32-bit register.
