notfet
Junior Member level 2
I have a new wifi shield(arduino brand model a000058). Using the github library the arduino will not compile in v1.0.1 but will compile in 1.0.5. I can connect using the example files but when I use SendRecieveudp, I do not receive udp packets. Using two iPhones, I can send udp packets from one to another so that is telling me that my router is forwarding the ports correctly. But I cannot receive udp packets to the arduino. Using that same port. What could be wrong? Do I need to upgrade the wifi shield firmware? The arduino connect light is on.
