+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
  1. #1
    Newbie level 6
    Points: 75, Level: 1
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    inverter circuit with 12V/7.2AH
    I want inverter circuit of 12V/7.2ah at mosfet.
  2. #2
    Advanced Member level 5
    Points: 33,525, Level: 44
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    tpetar's Avatar
    Join Date
    Sep 2010
    Pancevo-Belgrade, Serbia
    Posts
    6,427
    Points
    33,525
    Level
    44
    Re: inverter circuit with 12V/7.2AH
    Quote Originally Posted by pasala228 View Post
    We will send one with DHL on Monday immediately.
    You should give more details what you need.
    Inverter can use 12V 7,2Ah battery and produce 220V/110V using MosFETs. Is that what you want?
    SMPS/Iron core, square wave/modified sine wave/pure sinewave, output power?
    Describe what you plan to power with this inverter?
    How you plan to charge battery, is that needed?
    “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.” Nikola Tesla
    2 members found this post helpful.
  3. #3
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    Yes sir....output 220v sine wave using mosfets.
    Can u please tell me about the maximum wattage with this circuit??
    Sir ,please send me the charging circuit also for 12V/7.2ah?
    By using transformer..
  4. #4
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    Inverter 12V / 230V 50Hz with modified sine wave
    http://translate.googleusercontent.c...50Hw3D6Q_gQLwQ
    Switching (transformerless) DC/AC 12V/230V 150W modified sine wave inverter
    http://danyk.cz/menic230_6_en.html
    You can play with filtering to get sinewave, pure sinewave is more complex to build.
    200W 12V to 220V Sinus Inverter SG3525 Ferit Trafo
    Click image for larger version.
    Keep in mind that battery what you plan to use is small and introduce yourself with battery capabilities (7,2Ah). Get manufacturer datasheet and read.
    Adaptable 12vDC/220vAC Pure Sinewave Inverter
    http://www.instructables.com/id/Adap...ve-Inverter-1/
    1 members found this post helpful.
    •   Alt7th April 2013, 15:53
      advertising
  5. #5
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    Sir how much wattage..??
    Current rating of transformer 9v to 230v
  6. #6
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    For first project if you use SMD MosFETs power can be in range from 50W to 100W.
    Try to read posted material.
  7. #7
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    What will be the maximum output with this if I use transistors?and givem me the circuit diagram
    I am planning to use one tubelight and one fan, please send me the appropriate circuit diagram using mosfet or transistor...please???????
    •   Alt8th April 2013, 12:18
      advertising
  8. #8
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    Is this your first project in electronics?
    What is tubelight? Something from StarWars?
    •   Alt8th April 2013, 12:20
      advertising
  9. #9
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    Fluorescent lamp sir.
  10. #10
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    Oh see now. For neon light you can use simple inverter, and AC motor for fan will need pure sine, or at least better modified sine.
    From my aspect of view, if you plan to make this for personal usage, better buy used or new pure sine or modified sine wave offline UPS 12V-7Ah. I think this will be cheaper variant. In other case if you want to learn how to build this, then take some circuit and start working. First circuit is pretty simple, you can do all in SMD.
  11. #11
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    Thanq sir,but the current rating of transformer and remaining parts info please...
  12. #12
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    We say earlier 50-100W.
  13. #13
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    Sir please give me the components info..
  14. #14
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    What exactly info about parts you need? You can see parts values in circuits.
    MosFETs ID is given in upper part of circuit. Try to read whole description text.
  15. #15
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    Sir u have given 4 nchannel mosfets in the circuit but u gave 6 types of mosfets among them which I have to use....
  16. #16
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    You can use any from suggested.
  17. #17
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    Sir,can I use 9b to 230v,2amp transformer???
  18. #18
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    What is 9b? You mean 9V.
    2A on primar or secundar winding ?
  19. #19
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    Ya sir...2amp on 9v side I mean primary side...
    •   Alt18th April 2013, 08:09
      advertising
  20. #20
    Newbie level 6
    Join Date
    Apr 2013
    Posts
    12
    Points
    75
    Level
    can I use the above....or any please tell me..
