+ Post New Thread
Results 1 to 19 of 19
  1. #1
    Member level 1
    Points: 265, Level: 3
    Join Date
    Oct 2012
    Posts
    41
    Points
    265
    Level
    fixed point to std_logic_vector conversion in vhdl
    Hai,
    I have 4 constant value with fixed point values (0.123, 0.431,-0.871) and I want to build the ROM table for this constant. How to convert the fixed point value to std_logic_vector type?. Is it possible? If yes, how to do that? Thanks in advance
  2. #2
    Advanced Member level 5
    Points: 35,441, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Re: fixed point to std_logic_vector conversion in vhdl
    Yes. The floating point library at www.vhdl.org/fphdl has a to_slv function.
    1 members found this post helpful.
  3. #3
    Member level 1
    Join Date
    Oct 2012
    Posts
    41
    Points
    265
    Level
    Quote Originally Posted by TrickyDicky View Post
    Hai TrickyDicky,
    Thanks, I get it.
    Hai,
    I change my vhdl package as below:
    library IEEE;
    library ieee_proposed;
      use ieee_proposed.fixed_pkg.all;
      use IEEE.STD_LOGIC_1164.all;
      use ieee.numeric_std.all;
    package MDWT_PKG is
      -- 2's complement numbers
    	constant h0 : sfixed(3 downto -4)  := 0.483;
    	constant h1 : sfixed(3 downto -4) := 0.837;
    	constant h2 : sfixed(3 downto -4) := 0.224;
    	constant h3 : sfixed(3 downto -4) := -0.129;
    However I get this error : "Type sfixed does not match with the real literal". What my mistake? Thanks in advance
    •   Alt11th March 2013, 10:52
      advertising
  4. #4
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    you need to use the to_sfixed function to convert the real number to an sfixed type.
  5. #5
    Member level 1
    Join Date
    Oct 2012
    Posts
    41
    Points
    265
    Level
    Hai TrickyDicky,
    I do the to_sfixed at the vhdl package, whilst in the ROM I convert them to std_logic_vector using to_slv. Below is the vhdl package:
    library IEEE;
    package MDWT_PKG is
      signal n1 : sfixed(3 downto -4);
      signal n2 : sfixed(4 downto -4);
    	constant h0 : sfixed(3 downto -4)  := to_sfixed(0.483,n1);
    	constant h1 : sfixed(3 downto -4)  := to_sfixed(0.837,n1);
    	constant h2 : sfixed(3 downto -4)  := to_sfixed(0.224,n1);
    	constant h3 : sfixed(4 downto -4)  := to_sfixed(-0.129,n2);
    However, the bits for all the constant values are not same. h0-h2 have 8bits (7 downto 0) and h3 have 9bits (8 downto 0). How to make them synchronize (same bits)? I think if I make ho-h2 to 9bits, it will change the original value. How to do this? Thanks in advance
  6. #6
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Why have you decalred a signal in the package?
    you can just specify the values in the other version of the to_sfixed(X, high, low) function:
    constant h3 : sfixed(4 downto -4) := to_sfixed(-0.129, 4, -4);
    having more bits for h0-2 will not affect the data value or the result value. You just get extra 0's at the front.
  7. #7
    Advanced Member level 1
    Points: 3,030, Level: 12
    Join Date
    Feb 2012
    Jeonju, South Korea
    Posts
    464
    Points
    3,030
    Level
    12
    Is this thing synthesizable as well. I mean apart from making ROM table if we want to use it somewhere else in the code
    When the going gets weird, the weird turn pro.
    H.S. Thompson
    •   Alt11th March 2013, 15:34
      advertising
  8. #8
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Yes. I have used it many times successfully.
  9. #9
    Member level 1
    Join Date
    Oct 2012
    Posts
    41
    Points
    265
    Level
    Hai TrickyDicky,
    I have correct the package and ROM vhdl codes. I set all the constant h0-h3 : sfixed(9 downto -4), I set to 14bits/elements. Then at the ROM I convert the like:
    type ROM_TYPE is array (0 to (2**ROMADDR_W)-1)
                of STD_LOGIC_VECTOR(13 downto 0);
      constant rom : ROM_TYPE :=
        (                --error occur at this line
        (others => '0'),
         to_slv( h0 ),
         to_slv( h1 ),
         to_slv( h0+h1 ),
         to_slv( h2 ),
         to_slv( h2+h0 ),
         to_slv( h2+h1),
         to_slv( h2+h1+h0 ),
         to_slv( h3 ),
         to_slv( h3+h0),
         to_slv( h3+h1),
         to_slv( h3+h1+h0 ),
         to_slv( h3+h2),
         to_slv( h3+h2+h0 ),
         to_slv( h3+h2+h1 ),
         to_slv( h3+h2+h1+h0),
    However, when I compile the project I get this error: "Expression has 15 elements ; expected 14". What my mistake? Thanks in advance
    •   Alt11th March 2013, 16:13
      advertising
  10. #10
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Well, you didnt say where the error is pointing, but Id have thought the error was quite obvious. The value has 15 bits, but the entries in the rom are only 14 bits according to your type.
    If you declared h0-h3 as sfixed, you need to know that h0 + h1 will produce a result that is 1 bit larger. You need to resize the result with the resize function.
  11. #11
    Member level 1
    Join Date
    Oct 2012
    Posts
    41
    Points
    265
    Level
    In the ROM entries, I set the bits to 14bits. But, how to resize the results in the ROM? Is it I need to do the addition operations first (outside the ROM) before take the results into the ROM? Thanks in advance
  12. #12
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    It doesnt matter where you do them. You can easily use the resize function on the result, either inside or outside the constant (it is not a ROM yet, it is just a constant definition).
  13. #13
    Member level 1
    Join Date
    Oct 2012
    Posts
    41
    Points
    265
    Level
    Hai TrickyDicky,
    I don't know how to use resize function,but I try to do like this:
        (others => '0'),
         to_slv( h0 ),
         to_slv( h1 ),
    	  STD_LOGIC_VECTOR(RESIZE(RESIZE(SIGNED(to_slv( h0)),ROMDATA_W))+(RESIZE(SIGNED(to_slv(h1))),ROMDATA_W)),
         to_slv( h2 ),
    Unfortunately, I get errors:
    ERROR:HDLCompiler:620 - "J:\MyResearch\Xilinx_Project\discretewavelettrans form\MDWT4\DWT\ROM.vhd" Line 50: Near signed ; type conversion does not match type unresolved_sfixed
    ERROR:HDLCompiler:1728 - "J:\MyResearch\Xilinx_Project\discretewavelettrans form\MDWT4\DWT\ROM.vhd" Line 50: Type error near romdata_w ; current type integer; expected type unresolved_sfixed
    ERROR:HDLCompiler:432 - "J:\MyResearch\Xilinx_Project\discretewavelettrans form\MDWT4\DWT\ROM.vhd" Line 50: Formal <size_res> has no actual or default value.
    ERROR:HDLCompiler:841 - "J:\MyResearch\Xilinx_Project\discretewavelettrans form\MDWT4\DWT\ROM.vhd" Line 50: Expecting type std_ulogic for <resize>.
    ERROR:HDLCompiler:854 - "J:\MyResearch\Xilinx_Project\discretewavelettrans form\MDWT4\DWT\ROM.vhd" Line 41: Unit <rtl> ignored due to previous errors.
    Can you give hint how to make the resize function? Thank in advance
  14. #14
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Thats probably the most overcomplicated attempt Ive ever seen...
    all you need is:
    to_slv( resize( H0 + H1, H0'high, H0'low) ),
    wouldnt it just be easier to declare H0 etc as real types and then do the conversion when you need them? then you dont need the resize functions:
    CONSTANT H0 : real := 0.483;
    ....etc
    CONSTANT H0_FP : sfixed(3 downto -4) := to_sfixed(H0, 3, -4);
    ..etc
    ...in the ROM Constant
    to_slv( to_sfixed( H0 + H1, H0'high, H0'low) ),
    --etc
    Or even better, why not just declare the ROM as an array of sfixed?
  15. #15
    Member level 1
    Join Date
    Oct 2012
    Posts
    41
    Points
    265
    Level
    Hai TrickyDicky,
    There are many ways to do the conversion in vhdl right,interesting. I will try to do your suggestions. Btw,thanks for your helps, I really appreciate it.
  16. #16
    Member level 1
    Join Date
    Oct 2012
    Posts
    41
    Points
    265
    Level
    Hai TrickyDicky,
    I do your second method,but get this error:
    Line 50: Prefix of attribute high is not a type mark
    Line 50: Formal <arg> has no actual or default value.
    Line 50: Indexed name prefix type unresolved_sfixed expects 1 d
        (others => '0'),
         to_slv( h0_FP ),
         to_slv( h1_FP ),
         to_slv(to_sfixed(h0+h1,h0'high,h0'low )),
         to_slv( h2_FP ),
         to_slv(to_sfixed(h2+h0,h2'high,h2'low)),
    Why the error occur and what my mistake? Thanks in advance
    I change the code and they run successfully.
    to_slv(to_sfixed(h0+h1,h0_FP'high,h0_FP'low )),
  17. #17
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    thats because 'high and 'low attributes can only be used on array types, not on real types.
    •   Alt12th March 2013, 08:46
      advertising
  18. #18
    Member level 1
    Join Date
    Oct 2012
    Posts
    41
    Points
    265
    Level
    Yes, you are right. Thanks TrickyDicky!
  19. #19
    Points: 49, Level: 1
    Join Date
    Feb 2015
    Posts
    Points
    49
    Level
    Quote Originally Posted by symlet View Post
    plz forward your whole code of fixed point rom/////////
