VHDL Type Mismatch error ndexed name returns a value whose type does not match the ty
programmingzeal
Newbie level 3
PAKISTAN
Please help me in solving the error since 2 weeks. This program a CPLD board, a switching board, LED board........ans we have to enlighten 8 LEDs when the corresponding push button is pressed from switch board.........This is the program purpose......
Error (10381): VHDL Type Mismatch error at CPLDBOARD_EB020_EPM7128.vhd(214): indexed name returns a value whose type does not match "IO8", the type of the target expression
PACKAGE_GLOBAL_VARIABLE.vhd
1.	--PACKAGE DECLARED TO MAKE USE OF GLOBAL VARIABLE(s)
2.	-- AS SUPPORTED IN VHDL SINCE VHDL'93
3.
4.	LIBRARY ieee;
5.	USE ieee.std_logic_1164.all;
6.	USE ieee.numeric_std.all;
7.	USE ieee.std_logic_signed.all;
8.
9.	PACKAGE global_variable IS
10.
11.	TYPE IO8 IS ARRAY (7 DOWNTO 0) OF STD_LOGIC;
12.	TYPE IO4 IS ARRAY (3 DOWNTO 0) OF STD_LOGIC;
13.
14.	END PACKAGE;
1.	LIBRARY work;
2.	USE work.global_variable.all;
3.	LIBRARY ieee;
4.	USE ieee.std_logic_1164.all;
5.	USE ieee.numeric_std.all;
6.	USE ieee.std_logic_signed.all;
7.
8.	ENTITY SWITCHBOARD_EB007 IS
9.	PORT (
10.	CLK_IN_S: IN STD_LOGIC;
11.	RESET_S:  IN STD_LOGIC;
12.	BIT_IN_SWITCH: IN IO8;
13.	BIT_OUT_SWITCH: OUT IO8);
14.	END SWITCHBOARD_EB007;
15.
16.	ARCHITECTURE SWITCHES_PUSH_BUTTONS OF
17.	SWITCHBOARD_EB007 IS
18.
19.	BEGIN
20.	PUSH_BUTTONS: PROCESS (CLK_IN_S, RESET_S)
21.
22.	BEGIN
23.	IF RESET_S = '1' THEN
24.	FOR i IN 0 TO 7 LOOP
25.	BIT_OUT_SWITCH(i) <= '0';
26.	END LOOP;
27.	ELSIF (CLK_IN_S'EVENT AND CLK_IN_S = '1') THEN
28.	FOR j IN 0 TO 7 LOOP
29.	IF BIT_IN_SWITCH(j) = '1' THEN
30.	BIT_OUT_SWITCH(j) <= BIT_IN_SWITCH(j);
31.	END IF;
32.	END LOOP;
33.	END IF;
34.	END PROCESS PUSH_BUTTONS;
35.	END SWITCHES_PUSH_BUTTONS;
36.
37.	LIBRARY work;
38.	USE work.global_variable.all;
39.	LIBRARY ieee;
40.	USE ieee.std_logic_1164.all;
41.	USE ieee.numeric_std.all;
42.	USE ieee.std_logic_signed.all;
43.
44.	ENTITY LEDBOARD_EB004 IS
45.	PORT (
46.	CLK_IN_L: IN STD_LOGIC;
47.	RESET_L:  IN STD_LOGIC;
48.	BIT_IN_LED: IN IO8;
49.	D0, D1, D2, D3, D4, D5, D6, D7: OUT STD_LOGIC);
-- BLUE LEDS OR DEPENDS ON YOUR CHOICE (RED/ GREEN/ BLUE/ YELLOW LEDS)
50.	END LEDBOARD_EB004;
51.
52.	ARCHITECTURE ENLIGHTEN_LEDS OF
53.	LEDBOARD_EB004 IS
54.
55.	BEGIN
56.	ENLIGHTEN_LEDS:	PROCESS(CLK_IN_L, RESET_L)
57.
58.	BEGIN
59.	IF RESET_L = '1' THEN
60.	D0 <= '0';
61.	D1 <= '0';
62.	D2 <= '0';
63.	D3 <= '0';
64.	D4 <= '0';
65.	D5 <= '0';
66.	D6 <= '0';
67.	D7 <= '0';
68.	ELSE
69.	WAIT UNTIL CLK_IN_L = '1' AND CLK_IN_L'EVENT;
70.	IF BIT_IN_LED(0) = '1' THEN
71.	D0 <= BIT_IN_LED(0);
72.	END IF;
73.	IF BIT_IN_LED(1) = '1' THEN
74.	D1 <= BIT_IN_LED(1);
75.	END IF;
76.	IF BIT_IN_LED(2) = '1' THEN
77.	D2 <= BIT_IN_LED(2);
78.	END IF;
79.	IF BIT_IN_LED(3) = '1' THEN
80.	D3 <= BIT_IN_LED(3);
81.	END IF;
82.	IF BIT_IN_LED(4) = '1' THEN
83.	D4 <= BIT_IN_LED(4);
84.	END IF;
85.	IF BIT_IN_LED(5) = '1' THEN
86.	D5 <= BIT_IN_LED(5);
87.	END IF;
88.	IF BIT_IN_LED(6) = '1' THEN
89.	D6 <= BIT_IN_LED(6);
90.	END IF;
91.	IF BIT_IN_LED(7) = '1' THEN
92.	D7 <= BIT_IN_LED(7);
93.	END IF;
94.	END IF;
95.	END PROCESS ENLIGHTEN_LEDS;
96.	END ENLIGHTEN_LEDS;
97.
98.	LIBRARY work;
99.	USE work.global_variable.all;
100.	LIBRARY ieee;
101.	USE ieee.std_logic_1164.all;
102.	USE ieee.numeric_std.all;
103.	USE ieee.std_logic_signed.all;
104.
105.	ENTITY CPLD_Crystal_Clock_Generator IS PORT(
106.	CLK_IN : IN STD_LOGIC;
107.	CLK_OUT : OUT STD_LOGIC);
108.	END CPLD_Crystal_Clock_Generator;
109.
110.	ARCHITECTURE System_Clock OF
111.	CPLD_Crystal_Clock_Generator IS
112.
113.	BEGIN
114.
115.	PROCESS (CLK_IN)
116.
117.	BEGIN
118.	CLK_OUT <= NOT CLK_IN;
119.	END PROCESS;
120.	END System_Clock;
121.
122.	LIBRARY work;
123.	USE work.global_variable.all;
124.	LIBRARY ieee;
125.	USE ieee.std_logic_1164.all;
126.	USE ieee.numeric_std.all;
127.	USE ieee.std_logic_signed.all;
128.
129.	ENTITY CPLDBOARD_EB020_EPM7128 IS
130.	PORT (
131.	CLK_IN_CPLD: 	IN STD_LOGIC;
132.	CLK_OUT_CPLD:	OUT STD_LOGIC;
133.	RESET_CPLD:  IN STD_LOGIC;
134.	PORT_CPLD_ARRAY1_DB9_PIN8TO1: INOUT STD_LOGIC;
135.	PORT_CPLD_ARRAY2_DB9_PIN8TO1: INOUT STD_LOGIC;
136.	PORT_CPLD_ARRAY3_DB9_PIN8TO1: INOUT STD_LOGIC;
137.	PORT_CPLD_ARRAY4_DB9_PIN8TO1: INOUT STD_LOGIC;
138.	PORT_CPLD_ARRAY5_DB9_PIN8TO1: INOUT STD_LOGIC;
139.	PORT_CPLD_ARRAY6_DB9_PIN8TO1: INOUT STD_LOGIC;
140.	PORT_CPLD_ARRAY7_DB9_PIN8TO1: INOUT STD_LOGIC;
141.	SIGNAL PORT_CPLD1_DB9_PIN9: STD_LOGIC;
142.	SIGNAL PORT_CPLD2_DB9_PIN9: STD_LOGIC;
143.	SIGNAL PORT_CPLD3_DB9_PIN9: STD_LOGIC;
144.	SIGNAL PORT_CPLD4_DB9_PIN9: STD_LOGIC;
145.	SIGNAL PORT_CPLD5_DB9_PIN9: STD_LOGIC;
146.	SIGNAL PORT_CPLD6_DB9_PIN9: STD_LOGIC;
147.	SIGNAL PORT_CPLD7_DB9_PIN9: STD_LOGIC);
148.	END CPLDBOARD_EB020_EPM7128;
149.
150.	ARCHITECTURE PROGRAM_CPLDBOARD OF
151.	CPLDBOARD_EB020_EPM7128 IS
152.
153.	TYPE GND9 IS ARRAY (7 DOWNTO 0) OF STD_LOGIC;
154.
155.	COMPONENT CPLD_Crystal_Clock_Generator
156.	PORT (CLK_IN_CPLD: 	IN STD_LOGIC;
157.	CLK_OUT_CPLD:	OUT STD_LOGIC);
158.	END COMPONENT;
159.	COMPONENT LEDBOARD_EB004
160.	PORT (CLK_IN_L, RESET_L: IN STD_LOGIC;
161.	BIT_IN_LED: IN IO8;
162.	BIT_OUT_LED: OUT IO8);
163.	END COMPONENT;
164.	COMPONENT SWITCHBOARD_EB007
165.	PORT (CLK_IN_S, RESET_S: IN STD_LOGIC;
166.	BIT_IN_SWITCH: IN IO8;
167.	BIT_OUT_SWITCH: OUT IO8);
168.	END COMPONENT;
169.	COMPONENT PORT_CPLD1
170.	PORT (PORT_CPLD_ARRAY1_DB9_PIN8TO1: IO8;
171.	SIGNAL PORT_CPLD1_DB9_PIN9: GND9);
172.	END COMPONENT;
173.	COMPONENT PORT_CPLD2
174.	PORT (PORT_CPLD_ARRAY2_DB9_PIN8TO1: IO8;
175.	SIGNAL PORT_CPLD2_DB9_PIN9: GND9);
176.	END COMPONENT;
177.	COMPONENT PORT_CPLD3
178.	PORT (PORT_CPLD_ARRAY3_DB9_PIN8TO1: IO8;
179.	SIGNAL PORT_CPLD3_DB9_PIN9: GND9);
180.	END COMPONENT;
181.	COMPONENT PORT_CPLD4
182.	PORT (PORT_CPLD_ARRAY4_DB9_PIN8TO1: IO8;
183.	SIGNAL PORT_CPLD4_DB9_PIN9: GND9);
184.	END COMPONENT;
185.	COMPONENT PORT_CPLD5
186.	PORT (PORT_CPLD_ARRAY5_DB9_PIN8TO1: IO8;
187.	SIGNAL PORT_CPLD5_DB9_PIN9: GND9);
188.	END COMPONENT;
189.	COMPONENT PORT_CPLD6
190.	PORT (PORT_CPLD_ARRAY6_DB9_PIN8TO1: IO8;
191.	SIGNAL PORT_CPLD6_DB9_PIN9: GND9);
192.	END COMPONENT;
193.	COMPONENT PORT_CPLD7
194.	PORT (PORT_CPLD_ARRAY7_DB9_PIN8TO1: IO8;
195.	SIGNAL PORT_CPLD7_DB9_PIN9: GND9);
196.	END COMPONENT;
197.
198.	CONSTANT VCC: BIT := '1';
199.	SIGNAL T: IO8;
200.	SIGNAL Q: IO8;
201.	SIGNAL CLK_INTERNAL: STD_LOGIC;
202.
203.	BEGIN
204.	stage0: CPLD_Crystal_Clock_Generator
205.	PORT MAP (NOT CLK_IN_CPLD, CLK_INTERNAL);
206.	stage1: PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1(1) => T(0), PORT_CPLD1_DB9_PIN9(0) => '-');
207.	stage2: PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1(2) => T(1), PORT_CPLD1_DB9_PIN9(1) => '-');
208.	stage3: PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1(3) => T(2), PORT_CPLD1_DB9_PIN9(2) => '-');
209.	stage4: PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1(4) => T(3), PORT_CPLD1_DB9_PIN9(3) => '-');
210.	stage5: PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1(5) => T(4), PORT_CPLD1_DB9_PIN9(4) => '-');
211.	stage6: PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1(6) => T(5), PORT_CPLD1_DB9_PIN9(5) => '-');
212.	stage7: PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1(7) => T(6), PORT_CPLD1_DB9_PIN9(6) => '-');
213.	stage8: PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1(8) => T(7), PORT_CPLD1_DB9_PIN9(7) => '-');
214.	stage9:  SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T(0), Q(0));
215.	stage10: SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T(1), Q(1));
216.	stage11: SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T(2), Q(2));
217.	stage12: SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T(3), Q(3));
218.	stage13: SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T(4), Q(4));
219.	stage14: SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T(5), Q(5));
220.	stage15: SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T(6), Q(6));
221.	stage16: SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T(7), Q(7));
222.	stage17: LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q(0), D0);
223.	stage18: LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q(1) , D1);
224.	stage19: LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q(2) , D2);
225.	stage20: LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q(3) , D3);
226.	stage21: LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q(4) , D4);
227.	stage22: LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q(5) , D5);
228.	stage23: LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q(6) , D6);
229.	stage24: LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q(7) , D7);
230.	CLK_OUT_CPLD <= CLK_INTERNAL;
231.	END PROGRAM_CPLDBOARD;
199. SIGNAL T: IO8;
200. SIGNAL Q: IO8;
T(0) is the lsb of T, which is an 8b value.
The port doesn't want T(0), as T(0) is only 1b. The port wants something that is 8b wide. Perhaps you only want one switchboard/ledboard instance, or perhaps you want these modules to have 1b IO.
Dear permute,
Many thanks for your reply and consideration.
You mean I should change either the Modules to have 1 bit IO. But then the question is how to light up 8 LEDs => use 8 LED boards?
Otherwise, should I use
stage1: PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1(1) => T, PORT_CPLD1_DB9_PIN9 => '--------');
214.	stage9:  SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T, Q);
222.	stage17: LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q, LED_R(0-7));
LED_R(0-7) needs to be figured out. If not like this we can use
45.	PORT (
48.	BIT_IN_LED0: IN STD_LOGIC;
49.	BIT_IN_LED1: IN STD_LOGIC;
50:   BIT_IN_LED2: IN STD_LOGIC;
51:   BIT_IN_LED3: IN STD_LOGIC;
55. BIT_IN_LED7: IN STD_LOGIC;
56. D0, D1, D2, D3, D4, D5, D6, D7: OUT STD_LOGIC);
and in the port mapping we will use
Does this make sense?
Please reply.
Many thanks for pinpointing flaw a deep flaw.
Thanks again.
P.S. Also see attachment of CPLD board PIN structure....and requirement. Page 8 and page 4
Regards,
PZ
  • EB020-30-3.pdf
how many led's do you have? 8 or 64? you almost certainly are trying to solve the same problem in two different places.
8 leds: 8 modules each driving 1 led = 8 leds.
8 leds: 1 module driving 8 leds = 8 leds
64 leds: 8 modules each driving 8 leds = 64 leds.
in the 64 led case, the type of Q,D are incorrect and should be arrays of 8b values, or a 64b value with correct indexing on the port map connections.
Hi every body,
I thank you all from the core of my heart. The problem has been solved and it was in package where I was using array for IO8 STD_LOGIC. Now I am using STD_LOGIC_BIT_VECTOR. The problem is now of timing. I have attached TIMING reports and other reports of the project. Please let me know how to do away with timing mismatch of this model family. Please see attachments.
LIBRARY work;
LIBRARY ieee;
PORT (
		BIT_IN_SWITCH: IN STD_LOGIC_VECTOR(7 DOWNTO 0);
		BIT_OUT_SWITCH: OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
ARCHITECTURE SWITCHES_PUSH_BUTTONS OF SWITCHBOARD_EB007 IS
BEGIN
	BEGIN
			END LOOP;
				END IF;
			END LOOP;
		END IF;
LIBRARY work;
LIBRARY ieee;
PORT (
	BIT_IN_LED: IN STD_LOGIC_VECTOR(7 DOWNTO 0);
	LED: OUT STD_LOGIC_VECTOR(7 DOWNTO 0)); -- BLUE LEDS OR DEPENDS ON YOUR CHOICE (RED/ GREEN/ BLUE/ YELLOW LEDS)
END LEDBOARD_EB004;
ARCHITECTURE ENLIGHTEN_LEDS OF LEDBOARD_EB004 IS
BEGIN
	BEGIN
			LED(0) <= '0';
			LED(1) <= '0';
			LED(2) <= '0';
			LED(3) <= '0';
			LED(4) <= '0';
			LED(5) <= '0';
			LED(6) <= '0';
			LED(7) <= '0';
		ELSE
				LED(0) <= BIT_IN_LED(0);
			END IF;
				LED(1) <= BIT_IN_LED(1);
			END IF;
				LED(2) <= BIT_IN_LED(2);
			END IF;
				LED(3) <= BIT_IN_LED(3);
			END IF;
				LED(4) <= BIT_IN_LED(4);
			END IF;
				LED(5) <= BIT_IN_LED(5);
			END IF;
				LED(6) <= BIT_IN_LED(6);
			END IF;
				LED(7) <= BIT_IN_LED(7);
			END IF;
		END IF;
END ENLIGHTEN_LEDS;
LIBRARY work;
LIBRARY ieee;
ENTITY CPLD_Crystal_Clock_Generator IS PORT( CLK_IN : IN STD_LOGIC;
ARCHITECTURE System_Clock OF CPLD_Crystal_Clock_Generator IS
	BEGIN
		PROCESS (CLK_IN)
			BEGIN
		END PROCESS;
END System_Clock;
LIBRARY work;
LIBRARY ieee;
PORT (
		PORT_CPLD_ARRAY1_DB9_PIN8TO1: INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
		PORT_CPLD_ARRAY2_DB9_PIN8TO1: INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
		PORT_CPLD_ARRAY3_DB9_PIN8TO1: INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
		PORT_CPLD_ARRAY4_DB9_PIN8TO1: INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
		PORT_CPLD_ARRAY5_DB9_PIN8TO1: INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
		PORT_CPLD_ARRAY6_DB9_PIN8TO1: INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
		PORT_CPLD_ARRAY7_DB9_PIN8TO1: INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
ARCHITECTURE PROGRAM_CPLDBOARD OF CPLDBOARD_EB020_EPM7128 IS
	--TYPE GND9 IS ARRAY (7 DOWNTO 0) OF STD_LOGIC;
	END COMPONENT;
		LED: OUT STD_LOGIC_VECTOR); -- BLUE LEDS OR DEPENDS ON YOUR CHOICE (RED/ GREEN/ BLUE/ YELLOW LEDS)
	END COMPONENT;
	END COMPONENT;
		PORT (PORT_CPLD_ARRAY1_DB9_PIN8TO1: STD_LOGIC_VECTOR(7 DOWNTO 0);
				SIGNAL PORT_CPLD1_DB9_PIN9: STD_LOGIC_VECTOR(7 DOWNTO 0));
	END COMPONENT;
		PORT (PORT_CPLD_ARRAY2_DB9_PIN8TO1: STD_LOGIC_VECTOR(7 DOWNTO 0);
				SIGNAL PORT_CPLD2_DB9_PIN9: STD_LOGIC_VECTOR(7 DOWNTO 0));
	END COMPONENT;
		PORT (PORT_CPLD_ARRAY3_DB9_PIN8TO1: STD_LOGIC_VECTOR(7 DOWNTO 0);
				SIGNAL PORT_CPLD3_DB9_PIN9: STD_LOGIC_VECTOR(7 DOWNTO 0));
	END COMPONENT;
		PORT (PORT_CPLD_ARRAY4_DB9_PIN8TO1: STD_LOGIC_VECTOR(7 DOWNTO 0);
				SIGNAL PORT_CPLD4_DB9_PIN9: STD_LOGIC_VECTOR(7 DOWNTO 0));
	END COMPONENT;
		PORT (PORT_CPLD_ARRAY5_DB9_PIN8TO1: STD_LOGIC_VECTOR(7 DOWNTO 0);
				SIGNAL PORT_CPLD5_DB9_PIN9: STD_LOGIC_VECTOR(7 DOWNTO 0));
	END COMPONENT;
		PORT (PORT_CPLD_ARRAY6_DB9_PIN8TO1: STD_LOGIC_VECTOR(7 DOWNTO 0);
				SIGNAL PORT_CPLD6_DB9_PIN9: STD_LOGIC_VECTOR(7 DOWNTO 0));
	END COMPONENT;
		PORT (PORT_CPLD_ARRAY7_DB9_PIN8TO1: STD_LOGIC_VECTOR(7 DOWNTO 0);
				SIGNAL PORT_CPLD7_DB9_PIN9: STD_LOGIC_VECTOR(7 DOWNTO 0));
	END COMPONENT;
	--SIGNAL T: BIT_VECTOR(7 downto 0);
	--TYPE IO8 IS ARRAY (7 DOWNTO 0) OF STD_LOGIC;
	SIGNAL T: STD_LOGIC_VECTOR(7 DOWNTO 0);
	SIGNAL Q: STD_LOGIC_VECTOR(7 DOWNTO 0);
	SIGNAL R: STD_LOGIC_VECTOR(7 DOWNTO 0);
	BEGIN
		stage0:  CPLD_Crystal_Clock_Generator PORT MAP (NOT CLK_IN_CPLD, CLK_INTERNAL);
		stage1:  PORT_CPLD1 PORT MAP (PORT_CPLD_ARRAY1_DB9_PIN8TO1 => T, PORT_CPLD1_DB9_PIN9 => "--------");
		stage2:  SWITCHBOARD_EB007 PORT MAP (CLK_IN_CPLD, RESET_CPLD, T, Q);
		stage3:  LEDBOARD_EB004 PORT MAP (CLK_IN_CPLD, RESET_CPLD, Q, R);
I thank you all who spent their time on my problem solving.
I am getting 2 critical warnings and 4 warnings.
Kindly it is requested to please tell me the way how to deal with timing analysis......Your response is highly appreciated.
BEST REGARDS,
PZ
  • warnings-info.txt
  • db.zip
  • incremental_db.zip
  • quartz-altera-analyss.zip
