+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 2
    Points: 460, Level: 4
    Join Date
    Jul 2011
    Posts
    46
    Points
    460
    Level
    precision fullwave rectifier circuit with single supply opamp
    hello sir,
    i want to design a fullwave precision rectifier using a single supply opamp.i have a circuit of LM358 full wave rectifier,but it require at least 1v peak to peak voltage.in my case it will not be practical.i have to rectiy from around 10 mv peak to peak.i have one another option of opa2337,but it is not locally available.so somebody please help me.i thank you in advance
    •   Alt24th September 2011, 05:44
      advertising
  2. #2
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    Re: precision fullwave rectifier circuit with single supply opamp
    The question isn't very clear. Do you mean a dynamic range of 10 mV to 1 V or a gain of 100? In the latter case, you would want to apply the gain before the rectifier. Rectifier dynamic is mostly a problem related to available OP gain-bandwidth product. What's the intended signal bandwidth and acceptable absolute output error?
    I assume, that you aware of some single supply fullwave rectifier circuits from literature?
    •   Alt24th September 2011, 21:28
      advertising
  3. #3
    Member level 2
    Join Date
    Jul 2011
    Posts
    46
    Points
    460
    Level
    thank for reply.i want to precision rectify the signal of requency 45 hz to 65hz.i am not looking for amplification, simply precision rectification. signal in put may vary from 10mv peak to peak to 10v peak to peak.i simplyfy question,can any body suggest equavalent national semiconductor ic for opa 2337.thanks in advance
