eemark
Junior Member level 2
pls i need your help.it should work for example the sensor sense a samll amount of light so the bulb is in the maximum brightness.and if the light in the surrounding goes brighter the bulb light will dim until the light of the bulb is ok with the human eye.i mean the light of the bulb is adjustable depending on the light of the sorrounding.the lower the light in the sorrounding the greater light will be produce by the bulb.
anyone can post a design of the circuit and also a source code for it?
pls i need it asap
thank you for those who will help
pls i need it asap
