+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 5
    Points: 1,337, Level: 8
    Join Date
    Apr 2006
    Posts
    9
    Points
    1,337
    Level
    8
    Peak and hold Driver IC for Fuel Injector
    Hi ,
    I am looking out for peak and hold driver IC, i came across LM1949 from National. however i am not able to find any other similar IC that is used as an peak and hold injector driver, Please anyonw is aware of such an IC let me know.
    Regards,
    Nafis
    •   Alt1st June 2010, 05:28
      advertising
  2. #2
    Advanced Member level 5
    Points: 35,410, Level: 45
    Join Date
    Mar 2008
    USA
    Posts
    5,681
    Points
    35,410
    Level
    45
    You might dig into the "Megasquirt" EFI control development,
    and see what they use for low impedance injector options.
    Paralleling a "peak" driver (no DC limiting) and a "hold"
    driver (DC limited pulsed current source) is how I've done
    a few peak/hold designs. You simply have to have a pulse to
    control the peak path, that doesn't let the injector solenoid
    go overcurrent.
    I expect Delphi, Bosch, those kinds of folks are the bigger
    players when it comes to automotive related application
    drivers.
    •   Alt1st June 2010, 22:26
      advertising
  3. #3
    Newbie level 1
    Points: 253, Level: 3
    Join Date
    Jan 2012
    Posts
    Points
    253
    Level
    Re: Peak and hold Driver IC for Fuel Injector
    Please, can you explain how did you build peak and hold drivers more carefully??
    Thank you in advance
