+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 1
    Points: 1,830, Level: 9
    Achievements:
    7 years registered
    Join Date
    Dec 2008
    Posts
    17
    Points
    1,830
    Level
    9
    designing a 4 bit counter
    how do i design a 4 bit counter using d flip flops
    thanks
    •   Alt26th October 2009, 21:09
      advertising
  2. #2
    Junior Member level 3
    Points: 1,454, Level: 8
    Join Date
    Apr 2006
    Posts
    31
    Points
    1,454
    Level
    8
    Re: designing a 4 bit counter
    I assume you want a synchronous counter - Use the D flip flop excitation table and draw up your circuit excitation table with your present and next states. Use Karnaugh maps to solve for your D value for each flip flop(4 in your case 'coz it's a 4-bit counter).
    Here's a solution actually:
    http://www.csci.csusb.edu/schubert/t...f03/dw4bit.pdf
    •   Alt26th October 2009, 21:45
      advertising
  3. #3
    Achievements:
    7 years registered
    Join Date
    Dec 2008
    Posts
    17
    Points
    1,830
    Level
    9
    Thanks alot
    But what if I am constrained with 4 flipflops and only 3 logic gates
    Do you have any idea how this will work??
    Will it contain some sort of special feature ?
    Thanks alot again
    •   Alt26th October 2009, 22:10
      advertising
  4. #4
    Join Date
    Apr 2006
    Posts
    31
    Points
    1,454
    Level
    8
    What exactly are your design needs? The reason I ask is you can design a 4-bit asynchronous counter with just four D flip flops. If you have a requirement that states - count from (0000)b to (1100)b and not (1111)b, then you use NAND gates to asynchronously clear inputs of all flip flops once your counter reaches (1100)b. You could make a case for a similar asynch design which would use 4 FFs and 3 logic gates.
  5. #5
    Achievements:
    7 years registered
    Join Date
    Dec 2008
    Posts
    17
    Points
    1,830
    Level
    9
    my only constraint is that the counter consists of 4 d flip flops and any 3 logic gates
    I will try to implement it to count to 1100 as you told me
    I hope it works
    Thanks alot
    Added after 45 minutes:
    I am really sorry
    but can a counter count only even numbers??
    I am really sorry for the disturbance but I can't figure it out
    Thanks
    •   Alt27th October 2009, 00:03
      advertising
  6. #6
    Join Date
    Apr 2006
    Posts
    31
    Points
    1,454
    Level
    8
    Yup, you can design a synchronous four bit even counter. Draw up your state table with your present and next states, use the D-flip flop excitation table and karnaugh maps and extract your D value for each of the flip flops and you have your even counter! I am not sure how many logic gates it will use though, maybe you can reduce it down to three gates...
