+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Newbie level 1
    Points: 693, Level: 5
    Join Date
    Jan 2009
    San Jose, CA, USA
    Posts
    Points
    693
    Level
    dbc dbm
    How to convert dBc to dBm? Thanks.
    •   Alt31st January 2009, 03:15
      advertising
  2. #2
    Full Member level 6
    Points: 5,184, Level: 17
    Achievements:
    7 years registered
    RealAEL's Avatar
    Join Date
    May 2008
    Hotel California
    Posts
    383
    Points
    5,184
    Level
    17
    dbc to dbm
    dBm and dBc are completely different so there is no 'conversion' between the two.
    dBm - indicates the power measurement relative to 1 milliwatt. 0 dBm means no change from 1 mW, i.e. a power of exactly 1 mW. 3 dBm means 3 dB greater than 0 dBm. dBm is the relative difference to a fixed reference power of 1 mW.
    dBc — indicates the power relative to the power of the main carrier frequency; typically used to describe spurs, noise, channel crosstalk, and intermodal signals which may interfere with the carrier. dBc is the relative difference to an arbitrary reference power level, the power level of the carrier frequency.
  3. #3
    Advanced Member level 5
    Points: 33,056, Level: 44
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,645
    Points
    33,056
    Level
    44
    dbm dbc
    well, you could convert between them for a specific application. If you had a spur that was -50 dBc, and the carrier was at +10 dBm, then the spur would also be at -40 dBm.
  4. #4
    Full Member level 2
    Points: 1,679, Level: 9
    Join Date
    Oct 2008
    USA
    Posts
    133
    Points
    1,679
    Level
    9
    dbm to dbc
    Both of RealAEL and biff44 are right.dBm is compared with 1mW(dBm=10log(Power/1mW),and dBc is compared with carrier power(carrier(dBm)-power(dBm)).
    •   Alt1st February 2009, 00:47
      advertising
  5. #5
    Full Member level 2
    Points: 2,154, Level: 10
    Join Date
    Jul 2005
    Posts
    120
    Points
    2,154
    Level
    10
    dbm to dbc conversion
    I think RealAEL is wrong and biff44 is right.
  6. #6
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,645
    Points
    33,056
    Level
    44
    convert dbm to dbc
    everything RealAEL said is correct. I just gave a numerical example to further clarify his point.
  7. #7
    Full Member level 2
    Join Date
    Jul 2005
    Posts
    120
    Points
    2,154
    Level
    10
    dbc to dbm conversion
    Update: I think RealAEL is wrong and biff44 is wrong.
  8. #8
    Points: 39,631, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    convert dbc to dbm
    Quote Originally Posted by yendori
    If you know that both are wrong, then I conclude that you own the truth. Right ?
    May we share your knowledge ?
    •   Alt1st February 2009, 21:46
      advertising
  9. #9
    Full Member level 2
    Join Date
    Jul 2005
    Posts
    120
    Points
    2,154
    Level
    10
    dbc power
    LvW is right.
    No
  10. #10
    Newbie level 1
    Points: 640, Level: 5
    Join Date
    May 2009
    Posts
    Points
    640
    Level
    I think RealAEL is right
