how to make matching transfromer (50 ohm), power combiner (50 ohm) and bend in IE3D?
alokatzenith
Newbie level 6
PLz can anyone tell me how to make matching transfromer (50 ohm), power combiner (50 ohm) and bend. I making an array of patch antenna. I looked into IE3D manual but in that they have used unit MILS while I am using CM.
Re: IE3D help plz
Hi, alokatzenith:
It was discussed in simulating an array in the IE3D user's manual. You can change the length unit from mil to cm easily. Just select PARAMETERS->BASIC PARAMETERS and change it there.
Best regards,
Re: IE3D help plz
@jian
Thanx for the reply.
What I want to ask now will it make any difference if I change the dimensions of the transformer and power combiner. Since I have to change the dimension according to my needs. In the IE3D manual they have used power combiner and other stuffs according to their needs.
I m making an array of patch antenna. So I need the above said components.
