+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 4
    Points: 2,535, Level: 11
    Achievements:
    7 years registered
    Join Date
    May 2007
    Pakistan
    Posts
    74
    Points
    2,535
    Level
    11
    etd59
    I have some pieces of ETD 59 ferrite cores and I want to use them to build an inverter. Following are the details"
    Input voltage : 13.2 to 10V DC (Center tapped)
    Input current : 40 Amperes
    Output voltage (1) : 240v Ac
    Output voltage (2) : 15v Ac
    Output current : 3 Amperes
    operating frequency can be 20 to 30 KHz.
    please provide turns ratio and other details for making an inverter. Or other ETD ferrite core can be proposed if applicable. I;ll use SG3525 IC for building the inverter.
    •   Alt15th February 2008, 05:36
      advertising
  2. #2
    Full Member level 1
    Points: 2,149, Level: 10
    Khabree's Avatar
    Join Date
    Dec 2007
    Posts
    105
    Points
    2,149
    Level
    10
    etd 59
    If ETD core material is 3C8 or 3C90 or 3F3 etc then it can easily be used at 30KHz. SG3525 PWM IC is good for SMPS, also you can used LM3524, TL494 etc.
    As far as the output voltage is concerned, I am confused, because from your specs, it means 240V AC 30KHz (and you do not mean 240V AC 50Hz or 60Hz) then it will be a straight SMPS, otherwise strategy would be quite different.
    3 members found this post helpful.
  3. #3
    Member level 4
    Achievements:
    7 years registered
    Join Date
    May 2007
    Pakistan
    Posts
    74
    Points
    2,535
    Level
    11
    etd59 circuit
    Thanks for replying. The ETD core material can either be 3C8, 3C90 or 3F3.
    As far as the output voltage is concerned, it means 240V AC 30KHz which will be rectified to DC 240V for making 50Hz output. So, please guide me for the turns ratio & wire guage.
    1 members found this post helpful.
    •   Alt16th February 2008, 03:06
      advertising
  4. #4
    Full Member level 1
    Khabree's Avatar
    Join Date
    Dec 2007
    Posts
    105
    Points
    2,149
    Level
    10
    ferrite 3c8
    It means that you want to build a DC DC converter having an output of 240VDC and then with a MOSFET bridge, you will produce 220VAC. Right?
    (I build such circuit in 1993. Waooo, you pulled me to my past. Great Memories)
    Second thing you can calculate turns and other thing with the famous tx equation (below).
    You can also consult the book SMPS by Marty Brown it is written in more practical mode.
  5. #5
    Member level 4
    Achievements:
    7 years registered
    Join Date
    May 2007
    Pakistan
    Posts
    74
    Points
    2,535
    Level
    11
    building an inverter
    Thanks a lot. But I am unable to find any link or Equation in respect of famous tx equation. So, please help me for building the ferrite transformer.
    •   Alt16th February 2008, 09:30
      advertising
  6. #6
    Member level 4
    Points: 2,028, Level: 10
    Achievements:
    7 years registered
    Join Date
    Dec 2007
    Posts
    75
    Points
    2,028
    Level
    10
    www.ferrite etd59 transformer
    Using ferrite Transformer for this kind of operation is very difficult & the control circuit
    may also be very difficult to design (because it is not available on net I tried so hard)
    so it is good to use iron core transformer for Inverters it is easy to handle & Use.
    You can also fined good Circuits to build. :D
  7. #7
    Junior Member level 1
    Points: 229, Level: 2
    billu8660's Avatar
    Join Date
    Feb 2012
    Karachi
    Posts
    17
    Points
    229
    Level
    Re: www.ferrite etd59 transformer http://www.diysmps.com/forums/showthread.php?77-SMP
