+ Post New Thread
Results 1 to 16 of 16
  1. #1
    Junior Member level 3
    Points: 1,430, Level: 8
    Join Date
    Jul 2006
    Posts
    30
    Points
    1,430
    Level
    8
    lg tv problems
    Hello Everyone,
    i have 21inch TV from LG and now i am facing a problem that when i switched on the tv the standby led of the tv blinks for a few secnods and then automatically off.i keep trying but no result.i suspect that the power cable of the TV may be short or the fuse may be damaged.
    plz guide me in this regard.
    Regards
    Yousuf
  2. #2
    Full Member level 6
    Points: 6,204, Level: 18
    sawwa7's Avatar
    Join Date
    Oct 2004
    Posts
    331
    Points
    6,204
    Level
    18
    lg tv 21 inch
    Quote Originally Posted by engryousuf
    Hello Everyone,
    Regards
    Yousuf
    Hi my friend
    when u ask for help for tv or monitor or whatever please write down the model number and chassis number if available for the device u are asking for .
    so , please write the model number and chassis number ( preferred chassis number) of this LG tv to get more help and response .
    by the way , if the power cable is short it'll cause a problem to the home electric system and will never carry power to the tv to get the led bliks and i don't suspect the fuse as well as u have a power in ur tv .
    Kind Regards
  3. #3
    Full Member level 6
    Points: 5,110, Level: 16
    Join Date
    Feb 2006
    Posts
    336
    Points
    5,110
    Level
    16
    lg tv circuit
    power cable
    check it for connectivity
    there may b some break in it
    1 members found this post helpful.
    •   Alt10th January 2008, 16:07
      advertising
  4. #4
    Full Member level 6
    sawwa7's Avatar
    Join Date
    Oct 2004
    Posts
    331
    Points
    6,204
    Level
    18
    lg tv circuit diagram
    Quote Originally Posted by ehsanelahimirza
    power cable
    hi
    how come that the power cable has a break?
    he said that "the tv the standby led of the tv blinks for a few secnods and then automatically off"
    this means the power cable is ok and the tv is already powered by the power cable , there's another problem here and this may be a power supply problem or a horizontal stage problem and it needs more further inspections .
    Regards
  5. #5
    Full Member level 6
    Join Date
    Feb 2006
    Posts
    336
    Points
    5,110
    Level
    16
    lg tv diagram
    While we see fluctuations then its my practical experience to end with power cord. My pc monitor was doing the same
    2 members found this post helpful.
  6. #6
    Advanced Member level 3
    Points: 9,214, Level: 22
    cyberrat's Avatar
    Join Date
    Jun 2001
    In the sewers of the U.K.
    Posts
    859
    Points
    9,214
    Level
    22
    lg tv circuits
    simple, start at the source and work upwards.
    eliminate the power cable, the fuse and the on/off switch.
    As the LED is blinking then it shows that all 3 above items are working.
    Yes blinking led is a sign that there is a fault inside with the electronics and we'd need to know the model number to be more precise and what parts to check.
    Although it has to be said that there will be many thousands of volts inside that can cause harm so it is not something to do if you are unsure about doing it.
    Please do not PM me questions that are better asked in the PCB forum :)
  7. #7
    Member level 2
    Points: 1,337, Level: 8
    Join Date
    Feb 2007
    Pakistan
    Posts
    42
    Points
    1,337
    Level
    8
    lg tv faults
    Hi
    may be that led is used to indicate some minor fault,as i found in split air conditiner i use.
    in ac,led blinks for certain no of times ,as mentioned in manual for error indication
    u can check the manual.
    Regards
    Shakeel
    •   Alt11th January 2008, 12:19
      advertising
  8. #8
    Join Date
    Jul 2006
    Posts
    30
    Points
    1,430
    Level
    8
    tv lg 21 circuit
    21 inch LG SoundMax Plus
    Model No. CF-20D30
    the problem is when i turn the TV ON ,the TV automatically OFF within a second with no AV.
    i have shut down the TV for sometime and when i put it on, the TV is working.i don't know where the problem is?
    i have checked the Circuit and the circuit looks ok.
    plz guide me.
    Regards
    Yousuf
  9. #9
    Member level 1
    Points: 1,331, Level: 8
    Join Date
    Aug 2006
    Posts
    41
    Points
    1,331
    Level
    8
    lg 21 inch tv
    YOUR TV is in protection mode thats why it shutsdown..check the xray protection circuits.
  10. #10
    Join Date
    Jul 2006
    Posts
    30
    Points
    1,430
    Level
    8
    lg television 21 inches
    can anyone have the manual or the circuit diagram of my LG TV.
    i want to check the protection circuit.
    Also plz guide me how to ground the CRT. if you guide me through diagram then it will be better for me to undertand.
  11. #11
    Newbie level 2
    Points: 876, Level: 6
    Join Date
    Jan 2008
    Posts
    Points
    876
    Level
    l.g t.v circuit
    Replace C824 4.7uF at the PSU.
    also C408 1uF 160V
  12. #12
    Join Date
    Jul 2006
    Posts
    30
    Points
    1,430
    Level
    8
    circuit diagram of lg tv
    i need the circuit diagram of 21" LG SuperMax TV.
    Model No.CF-20D30 .
  13. #13
    Points: 1,187, Level: 7
    Join Date
    Jan 2008
    Posts
    Points
    1,187
    Level
    7
    21 inch lg tv
    hi engryousuf!
    here it is
    LG GOLDSTAR CF20D30R CF21D30R CF20D30RX CF21D30RX CHASSIS MC64B
    •   Alt27th January 2008, 00:13
      advertising
  14. #14
    Junior Member level 2
    Points: 929, Level: 6
    JunkMe's Avatar
    Join Date
    Jan 2008
    New Bedford, MA
    Posts
    20
    Points
    929
    Level
    www.lg tv of circuit
    I can buy tv for $25
  15. #15
    Join Date
    Jul 2006
    Posts
    30
    Points
    1,430
    Level
    8
    lg tv 21inch
    Thanks Moti.Did you find the solution of my problem.
  16. #16
    Newbie level 2
    Points: 847, Level: 6
    Join Date
    Mar 2008
    Posts
    Points
    847
    Level
    lg 21 inch
    i have a ld tv with the same problems.
    can you exlain in detail what i need to do to fix it as lg customer support are useless??
