+ Post New Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 50
  1. #1
    Newbie level 2
    Points: 918, Level: 6
    Join Date
    Dec 2007
    Posts
    Points
    918
    Level
    inverter circuit diagram
    I want a 12v dc to 220v ac inverter circuit diagram.please send me the simplest circuit diagram to make it practically for home appliances.
    The input should be 12v dc and the output should be 220v ac,50 Hz sine wave.
    Send me the circuit diagram as soon as possible.
  2. #2
    Banned
    Points: 22,963, Level: 36
    Join Date
    May 2007
    USA & Canada
    Posts
    437
    Points
    22,963
    Level
    36
    inverter circuit
    if not for high frequency, you will need a large transformer.
    7 members found this post helpful.
  3. #3
    Member level 4
    Points: 2,331, Level: 11
    Achievements:
    7 years registered
    chrismicro's Avatar
    Join Date
    Jul 2006
    South Africa
    Posts
    77
    Points
    2,331
    Level
    11
    circuit diagram of inverter
    You will need a sine wave in the first place, then I will recommend that you use at least 48 volts in other words 4X12 volt batteries, the higher the input voltage the lower the current and the less transistors will be needed, then you will need a large transformer, with a higher frequency than 50 or 60 Hz you can get away with a smaller transformer but that will not work with most domestic appliances, a transformer welding machine can be used as a transformer, then you will need a 50/60Hz sine wave signal that can be generated with a PIC16F627 with a R2R resistor pack connected to port B and some firmware for the PIC MCU, then you will need about 10 or more pairs of NPN/PNP power transistors and 10 or more driver transistors, the circuit is a simple push pull configuration, let me know if you can lay your hands on the hardware. TIP3055 NPN and TIP2955 PNP
    3 members found this post helpful.
  4. #4
    Full Member level 1
    Points: 3,268, Level: 13
    Achievements:
    7 years registered
    badboy2007's Avatar
    Join Date
    Feb 2007
    Cambodia
    Posts
    114
    Points
    3,268
    Level
    13
    dc to ac converter circuit diagram
    i need the sample circuit because i study about it
    thank i hope you will help me!!
    best regard !!
    5 members found this post helpful.
  5. #5
    Points: 15,530, Level: 30
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    sine wave inverter circuit diagram
    ha ha ha ha this is implemented very very much in Iraq due to no contineous electricity there
    •   Alt3rd February 2009, 00:35
      advertising
  6. #6
    Full Member level 1
    Achievements:
    7 years registered
    badboy2007's Avatar
    Join Date
    Feb 2007
    Cambodia
    Posts
    114
    Points
    3,268
    Level
    13
    inverter diagram
    oh... but i want to use Microcontroller to pure sine wave before input to the transformer na..because i see some inverter are pure square wave to the transformer so we can't use that inverter with Motor or fan....
    thank
    Best Rergard
    •   Alt3rd February 2009, 04:55
      advertising
  7. #7
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    dc to ac inverter circuit diagram
    realy i do not know but if u remember the fourier series
    the square wave is a fourier originaly sinusoidal of different harmonics, so that as i think, it is not a problem,
    this what i think,
    to all friends on this fourum, please help if i not on right answer.
    thanks
    2 members found this post helpful.
  8. #8
    Advanced Member level 5
    Points: 48,446, Level: 53
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Toronto area of Canada
    Posts
    8,423
    Points
    48,446
    Level
    53
    circuit diagram sine wave inverter
    A pure sine-wave inverter does NOT use a huge low frequency transformer like the very old square-wave inverters.
    Instead it used a high frequency PWM circuit driving a small high frequency ferrite transformer.
  9. #9
    Full Member level 1
    Achievements:
    7 years registered
    badboy2007's Avatar
    Join Date
    Feb 2007
    Cambodia
    Posts
    114
    Points
    3,268
    Level
    13
    ac to dc converter circuit diagram
    oh ok thank for your help but i'm still not clear i hope all friends can help me ...
    1 members found this post helpful.
  10. #10
    Newbie level 1
    Points: 612, Level: 5
    Join Date
    Jul 2009
    Guindy
    Posts
    Points
    612
    Level
    high frequency inverter circuit
    Did U get Inverters Ckt
    •   Alt9th July 2009, 12:00
      advertising
  11. #11
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    inverter circuit diagrams
    here is the circuit diagram with regards
  12. #12
    Aya2002's Avatar
    Join Date
    Dec 2006
    Iraq
    Posts
    1,142
    Points
    15,530
    Level
    30
    dc ac inverter circuit
    for more circuits see this link
    http://www.electronicsforu.com/electronicsforu/lab/
  13. #13
    Points: 621, Level: 5
    Join Date
    Sep 2009
    INDIA
    Posts
    Points
    621
    Level
    dc to ac circuit diagram
    i understood the circkut but what is the input 12V ?A to 220V ?A plz clear my doubt thnx
  14. #14
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,423
    Points
    48,446
    Level
    53
    circuit diagram for inverter
    Its output is a square-wave.
    Its max output is about only 100W.
    Its BC548 transistors have avalanche breakdown of their emitter-base junctions.
    It does not have voltage regulation.
  15. #15
    Join Date
    Sep 2009
    INDIA
    Posts
    Points
    621
    Level
    dc ac inverter circuit diagram
    ok i had 1000W wind mill generator but the problem is it produces dc out put can u people the moderator's help me giving a circuit of inverter to produce same 1000W
    as AC out put please make it sure by giving the values of resistor's or capacitor's or transister's plz i want to made it on home because i made the generator also at home as wind mill so what i want in simple is a circuit for 1000W DC to 1000WAC
    with values of resistor's or capacitor's or transister's can u help me plz and if u can please post the principle how DC is converted to a sine wave or square wave AC pleaseeeeeeee i am in meer need and only trusted on u r post
  16. #16
    Points: 20,015, Level: 34
    Achievements:
    7 years registered
    pranam77's Avatar
    Join Date
    Apr 2008
    INDIA
    Posts
    2,777
    Points
    20,015
    Level
    34
    12vdc to 220vac inverter circuit
    Quote Originally Posted by kacarot
    Please remember that moderators are not Harry potter's...:D:D:D
    •   Alt15th September 2009, 15:51
      advertising
  17. #17
    Advanced Member level 3
    Points: 6,212, Level: 18
    Join Date
    Apr 2006
    Hyderabad, India.
    Posts
    789
    Points
    6,212
    Level
    18
    I assume that you are an engineering student of (may be ) electronics
    I also hope you remember Newton's Laws. Any conversion will have wastage and 100% is not practicable. after knowing the fundamentals of basic science, perhaps your queries should be thoughtful. Please go through the wind mill methodologies.
    The energy is first saved in batteries, using charge controllers. suppose the battery used is 12V .
    then you may adopt a sine wave inverter from companies like Microtech, or square wave inverters from other suppliers and connect it. As and when power fails perhaps you can use the inverter to turn the stored energy of batteries into AC , until battery capacity is over. you should have guarding not to deep discharge or over charge, in order to sustain the battery life.
    We are here to impart little more of practicability in education and project design, and perhaps not to design and supply designs off shelf. suppose you start some design, got stuck , if you upload what all you have done, perhaps some one can advise you where things might be wrong and how to overcome. thereafter again it is for you to continue.
    I hope the aim of the site is also to guide and not to spoon feed.
  18. #18
    Full Member level 3
    Points: 3,580, Level: 14
    Join Date
    Mar 2005
    Europe
    Posts
    179
    Points
    3,580
    Level
    14
    ac dc converter circuit diagram
    I think a 1000W 12 to 230V inverter will not so easily feasible:
    the current to be switched (inverter) will be AT LEAST (90% efficiency) 90A!
    Your losses (transformer/cables/...) will be very high, so I can assume the real efficiency will be not higher than 60/70%.
    What I suggest is to work with at least 24V or better 48V as source voltage.
    P.S.: because this is a forum and you are not writing SMSs, it would be better if you try to switch to plain English instead of using those awful abbreviations! Thanks.
  19. #19
    Join Date
    Sep 2009
    INDIA
    Posts
    Points
    621
    Level
    Thnx mvs sarma u rembered me some thing by telling about faradays laws u know what i asked is hoe a dc is converted to ac while ac to dc can be done by some diodes and capacitors so i just asked the principle if possible ckt ok but only u r post is little bit help ful to me thnx
  20. #20
    Achievements:
    7 years registered
    Audioguru's Avatar
    Join Date
    Jan 2008
    Posts
    8,423
    Points
    48,446
    Level
    53
    dc ac converter circuit diagram
    Kacarot,
    Your English is so awful that I can't read it.
    Please go to a forum in your own country and talk in your own language.
    Most telemarketers here are from India. We cannot understand what they are saying.
