+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 3
    Points: 2,872, Level: 12
    DZC's Avatar
    Join Date
    Sep 2006
    Posts
    150
    Points
    2,872
    Level
    12
    How do we usually get rid of clock skew?
    I've heard PLL,DLL and SMD are often utilized in such situation,but I'm not sure is it possible for a Phase Detector achieve the zero phase difference when the loop is locked. If it's possible what technique must be used?
    Thanks for your reply!
    •   Alt28th November 2007, 11:57
      advertising
  2. #2
    Advanced Member level 1
    Points: 4,135, Level: 15
    Join Date
    Apr 2004
    shanghai,china
    Posts
    453
    Points
    4,135
    Level
    15
    clock skew is not same as zero phase difference.
    •   Alt29th November 2007, 12:08
      advertising
  3. #3
    Full Member level 2
    Points: 2,312, Level: 11
    Achievements:
    7 years registered
    Join Date
    Mar 2007
    Posts
    132
    Points
    2,312
    Level
    11
    In order to get rid of clock skew, I think the best solution is to use DLLs . I don' know a better method. However in order to minimize the skew of the DLL make sure to eliminate the deadzone. Also , minimize the charge pump mismatch.
    •   Alt29th November 2007, 19:36
      advertising
  4. #4
    Points: 4,719, Level: 16
    Join Date
    Sep 2004
    Posts
    461
    Points
    4,719
    Level
    16
    your question is not clear. If you have eg 2 outputs on different side of IC and want them to switch with 0 skew no PLL will help you. You need to do a proper layout to have the clock path as symetrical as possible.
    If you want clock in phase with input clock - PLL will work
