KaluzaKlein
Junior Member level 1
On an Infineon board (C167CS) I configure an output pin to be in open-drain mode and then I see with the oscilloscope that the output stays at 0V, whereas on a different pin, again in open drain, a LED attached to it switches on. Why don't I see any voltage change with the oscilloscope? Shouldn't a pullup resistor pull the output pin to some voltage when I change its value to logic '1' as in the case of the LED?
