stanislavb
Full Member level 2
I am interesting some basic question but from my point is not so trivial and it depends from internal structure discrete mosfets.
I am planning to use Mosfet N-channel with following parameter:
Vdsmax = 40V
Vgs = +- 20 V
Result simulation of the circuit give me following results
Vds = 31V
Vgs = 4v
Vgd = -35V(N-channel!)
Once in literature I found that Vgd max voltage higher than Vds max(even significantly larger). And If I exceed Vgd max of course I'll exceed Vdsmax. Nevertheless all above is true depending from internal Mosfet structure. Moreover frustrate me that Vgd is negative but Vds is positive. Shortly speaking do you have idea about relation all these maximum voltage in Discrete N-channel Mosfets
Thank you
Stas
Vdsmax = 40V
Vgs = +- 20 V
Vds = 31V
Vgs = 4v
Thank you
Stas
