measure of phase margin command file in hspice
mike_bihan
Full Member level 3
hspice phase margin
I was using command to measure phase margin in hspice.
.meas ac ugain_freq when Vdb(out)=0
.meas ac phase_margin ******* from=1 to=****
The question is how to find the minimum phase from 1Hz to unite-gain frequence?
[/b]
hspice .meas ac .measure ac gain
You can try
.measure ac min_phase MIN vp(out) from=1 to=ugain_freq
The phase_margin is, then, min_phase-(-180):
.measure ac phase_margin = param ('180+min_phase')
regards
.measure ac hspice
What happens ? It fails on both measurements (min_phase and phase_margin)?
I've already used this type of measurements several times. You should check the lis file to see if there is any relevant warning.
phase margin measurement spice
the reason i failed is that I typed ugain_freq as ugain-freq,
so when it is being refered in other .meas commands, it is misinterpreted as 'ugain'-'freq'.
Thanks, it is ok now.
hspice command to measure phase margin
For finding out the phase margin u connect a ACM(ac magnitude) of 1v to inverting or non-inverting terminal.
Re: hspice command to measure phase margin
.measure ac phaseM find vp(out) when v(out)=1
