need divide by 3 with 50% duty cycle circuit
srihari_adem
Junior Member level 1
divide by 3 circuit
hi all,
can any body send how to design divide by 3 with 50% duty cycle. Is there any general method to design odd dividers with 50% duty cycle
divide by 3 clock
Hi
Ya surely general method is there for it ,
For making odd dividers with 50% duty :
First Design the circuit how much mod counter you want , then take two T flip flop 1 +ve edge triggered and 1 -ve edge triggered (assume initial state for both of them is 1) and apply "1" input to both F/F.
For +ve Edge triggered F/F enable it at : 0 .
For -ve Edge triggered F/F enable it at : [ (n(n-1))/2 ] +1 .
and give output of both FF to an Exor gate ... you will get desired output.
divide by 3 circuit with 50 duty cycle
Clock Dividers Made Easy
Mohit Arora..
a gud papers in which ull find alll the speciality of clock division.
Added after 15 minutes:
this paper is there in this forum itself search and have it.
divide by three counter
uditkumar1983 said:
Hi
The solution seems to be a tricky one.
May you explain what N is considered to???
What do you mean by ENABLED AT??? so you mean initialed with 0 or 1???
clock divide by 3
This note can help you:
"Odd Number Divide By Counters with 50% Outputs and Synchronous Clocks"
h**p://www.onsemi.com/pub/Collateral/AND8001-D.PDF
divide by three circuit
srihari_adem said:
hi all,
SNUG PAPER, CLOCK MADE EASY.
quan228228
Added after 7 minutes:
i cant upload the file. Pls email me, if you want it.
quan228228@hotmail.com
quan228228
divide by 3 with 50 duty cycle
[/quote]
What do you mean by ENABLED AT??? so you mean initialed with 0 or 1???[/quote]
Hi .
N => Mod of ur Counter
ex. For divide by 3 take N=3.
Enabled means Enabling of F/F .
so you mean initialed with 0 or 1??? =>ya initialied with '1'...
Any other comment ????
divide by 3 counter
Hi .
Regards[/quote]
Thanx for the response but I still not satisfied with your explanations.
If I will substitute N=3 then the result as your equation is: 4
So what I can do with this value when you ask to enabled at 4!!!
It still not clear to me.
Please, Please, Please explain more.
It will be great if may discussed an example.
divide by 3 clock circuit
you have to use double edge of the clock if you want it implemented in syncronous design.
divide by 3 counter design
Hi .
Regards[/quote]
It will be great if may discussed an example.[/quote]
Hi
Sorry For my mistake it is [(n-1)/2]+1.
take Exp. for divide by 3 with 50 % duty cycle ..
so make circuit for Mod 3 counter (synchronous)...
so state of this counter is 0 ,1 & 2.
so now +ve edge F/F enabled it at 0
-ve edge triggered F/F enabled it at [(3-1)/2]+1 = 2
so now take o/p of both FF and give to input of exor gate ...
at o/p of exor gate you will get "Divide by3 with 50% duty cycle "..
Added after 1 minutes:
Hi
any other comments ?? Welcome..
divide by 3 counter circuit
Please check out this old post.
Enjoy!
Hope it helps
-no_mad
divide by 3 50% duty cycle
Hi .
Hi
Hi
Regards[/quote]
Coooooooooooooooooooooooooooooooooooooooooooooooooooooooooooool
Thanx very much!!!
