Oscillator Design with LATCH?
Full Member level 4
I analyzed oscillator circuit yesterday.
some oscillator circuit have no latch at the output but many oscillator circuit have latch circuit at the output of oscillator.
If I put the latch circuit to the output of oscillator, clock signal is divided by half.
following picture is oscillator circuit & its waveform.
in my opinion, Latch circuit is not necessary in the oscillator circuit.
Without Latch circuit, oscillator circuit could work properly.
Nevertheless, some oscillator have latch circuit. I guess it must be reasonable ground.
Why did somebody put the latch to the output of oscillator?
thanks
maybe for good duty cycle
    020170
usually, the comp output is saw-wave or sin-wave, a schmitt triger is needed when output it to square-wave, rs-latch can also used as a schmitt triger.
if divide by 2 used, you must need 50% duty cycle, as mists said.
    020170
