I need help with powering a microcontroller
skakz
Newbie level 6
pwering microcontroller
hi i am building a device with a 3.7 battery source and my microntroller needs max of 100mA and 3.6 V best voltage in 3.3
it needs 40 mA in normal mode and 60μA in powerdown mode
My major problem is to get 3.6 from 3.7 i will put a resistance and i get it;s value from V=IR which I do i use ?
if i used the 100mA and the microcontroller the R is 1Ω it's ok but if the current was less the voltage on the pin will be high
if i used 60μA then when the micrcontroller needs 40mA the voltage on the pin will be less than 3 !!
please some help me
Visit **broken link removed**
Re: pwering microcontroller
Instead of a resistor use Schottky Barrier Diode with Vf≈0.35V ..
For example,
BAT15 has Vf=0.32V @ 10mA ..
Regards,
IanP
Instead of a resistor use zenner diode 3.6V
    skakz
Zener can be good choice.....but I think you can feed 3.7V direclty to your uC, it should tolerate it!! Check the specs in the datasheet, I'm pretty sure it should work out.
Good luck
For example,
Regards,
IanP
what is schottky barrier diode
Added after 4 minutes:
the zinner diode will help in case of the the voltage increases but will help in the other case
or
the zinner will provide V of 3.6 what ever the current is
Added after 1 minutes:
Good luck
it works from 3 to 3.6
A shottky barrier diode is just one type of diode. Its advantage in this case is its low forward voltage drop. In order to use as IanP suggested, you have to put it in series with your battery. I think this option is better than using a zener diode.
Make sure that the voltage of the battery you intend to use doesn't go down with it state of charge. Lithium-ion batteries are a good choice, their voltage stays constant until their end-of-life.
You can also use a low-dropout regulator...
I also suggest that you don't try to use 3.7V directly, usually 3.6V is the absolute maximum rating!
