Unite two object in HFSS
baby_1
Advanced Member level 1
Hello
As you see I can't unite two object with "Unite" command.what is my mistake?
you can't unite a surface with solid, your patch should be with certain thickness.
Reactions: baby_1
    baby_1
you should know that intersection between solids is prohibited. you should modify the dimensions or subtract the substrate from the coaxial.
In real we punch the inner core of coaxial cable to patch and it is common that we have intersection between inner core and substrate. but it shows me "[error] Objects "Substarte" and "CoaxIn" intersect.".
and for simulate the coaxial cable we should draw three cylindrical shape?(inner core material is PEC , second cylindrical shape is vaccum and the last one should be PEC?)
yes your whole coaxial should not intersect the substrate even the vacuum and the inner.
Reactions: baby_1
    baby_1
