PCB: 3 point for automatic placing
tahtouh
Junior Member level 2
hello
3 point should be placed in a PCB to be a referene for placing machin
i want to know if this 3 points should be a holl or others
if they should have a particular placement or it is enougth to be non linear
thank's
I am struggling to understand what you are asking.
However - try googling for Fiducial marks and SMEMA
Hi tahtouh,
I think you are asking about the fiduciary marks...you need not have a hole....
Just have it as an SMD pad and solder mask must be opened...No need paste or silk....
There are two types of fiducials Global and Local....You probably need to add Three global fiducials, one at each corner of your PCB.
For Fine pitch components you need to add two fiducials diagnal(optional) to each other....
For more information try googling for fiduciary marks and at SMEMA...
Shabu.
Hi tahtouh,
Shabu.
thank you, this is exactely what i need
but are there specific function with altium designer to place fiduciary marks, or i'm only in need to place a pad
thank's again
and sorry for my english :oops:
You only need to place a pad with mask opened......
(Size of the pad varies according to manufacturers).
You can follow 40Mil circular pad and mask opened for 70Mil(Minimum)....
Shabu..
