the_pro
Junior Member level 1
hello...every one.
i have used 6t sramcell in my SRAM design.
for the read stability , i have optimized my cell by changing the cell ratio (ratio of the width of pull down nmos to pass nmos transistor) from 1 to 4. i kept pull up transistor width fix.
i observed that from cell ratio 1 to 2 , my read SNM improved but from 2 to 4 it again degraded.
and it is clear that if i will go beyond 4 then it will give less read SNM.
i have attached butterfly curve resutls.
is this result right ?
give me your suggestions .... thank u.
