[SOLVED] problem with lcd interfacing with pic18f4550
project1
Junior Member level 1
hello,
I am trying to interface a JHD162A LCD to pic18f4550. Its only showing a row of black boxes. Can someone pls help me out with this. I have given the code below. I'm using microchip C18 compiler with MPLAB.
#include<p18f4550.h>
#include<delays.h>
#pragma config FOSC = HS
#pragma config WDT = OFF
#pragma config PWRT = OFF
#pragma config CP0 = OFF
#pragma config PBADEN = OFF
//LCD Control pins
#define rs LATAbits.LATA0
#define rw LATAbits.LATA1
#define en LATAbits.LATA2
//LCD Data pins
#define lcdport LATB
void dis_cmd(unsigned char);
void dis_data(unsigned char);
void lcdcmd(unsigned char);
void lcddata(unsigned char);
void lcd_ini(void);
void main(void)
	unsigned char data0[]="Hello";
	unsigned int i=0;
	TRISB=0;			// Configure Port B as output port
	LATB=0;
	TRISA = 0;
	LATA = 0;
	lcd_ini();			// LCD initialization
	while(data0[i]!='\0')
		dis_data(data0[i]);
		Delay10KTCYx(400);		//Delay_ms(800);
		i++;
void lcd_ini()
	dis_cmd(0x02);		// To initialize LCD in 4-bit mode.
	dis_cmd(0x28);		// To initialize LCD in 2 lines, 5x7 dots and 4bit mode.
	dis_cmd(0x0C);
	dis_cmd(0x06);
	dis_cmd(0x80);
void dis_cmd(unsigned char cmd_value)
	unsigned char cmd_value1;
	cmd_value1 = (cmd_value & 0xF0);	// Mask lower nibble because RB4-RB7 pins are being used
	lcdcmd(cmd_value1);			// Send to LCD
	cmd_value1 = ((cmd_value<<4) & 0xF0);	// Shift 4-bit and mask
void dis_data(unsigned char data_value)
	unsigned char data_value1;
	data_value1=(data_value&0xF0);
	lcddata(data_value1);
	data_value1=((data_value<<4)&0xF0);
void lcdcmd(unsigned char cmdout)
	lcdport=cmdout;		//Send command to lcdport=PORTB
	rs=0;
	rw=0;
	en=1;
	Delay10KTCYx(25);	//Delay_ms(50);
	en=0;
void lcddata(unsigned char dataout)
	lcdport=dataout;	//Send data to lcdport=PORTB
	rs=1;
	rw=0;
	en=1;
	en=0;
You need delays when enable is low
        rs=0;
	rw=0;
	en=1;
	Delay10KTCYx(1);	//small delay
	en=0;
I just added the delays in lcdcmd() and lcddata() functions. It still didnt work.
I added a delay of 100ms and tried.
void main(void)
	unsigned int i=0;
	LATB=0;
	TRISA = 0;
	LATA = 0;
	Delay10KTCYx(50);	//Delay_ms(100);
		dis_data(data0[i]);
		i++;
I went through the other thread. I checked the connections once again with the multimeter. The lcd is receiving 5V and I'm not driving anything else. The supply is given only to the microcontroller and to the lcd.
You not have the correct initialization routine, look on **broken link removed**at page 10
I changed the lcd initialization function as follows but still same problem.
void lcd_ini()
	Delay10KTCYx(10);	//Delay_ms(20)
	dis_cmd(0x30);
	Delay10KTCYx(5);	//Delay_ms(10)
	dis_cmd(0x30);
	Delay1KTCYx(1);		//Delay_us(200)
	dis_cmd(0x30);
	dis_cmd(0x0C);
	dis_cmd(0x06);
Before setting interface to 4 bits you should use lcd_cmd function that write just one nibble:
void lcd_ini()
	lcd_cmd(0x03);
	lcd_cmd(0x03);
	lcd_cmd(0x03);
	lcd_cmd(0x02);           //Function set
	dis_cmd(0x0C);
	dis_cmd(0x06);
I tried using the code you suggested. But still its the same problem.
Try the following code (lcdport uses only high nibble, so you should have the command prepared for this)
void lcd_ini()
	lcd_cmd(0x30);
	lcd_cmd(0x30);
	lcd_cmd(0x30);
	lcd_cmd(0x20);           //Function set
	dis_cmd(0x0C);
	dis_cmd(0x06);
hello,
I think you should check these two functions. How the 4 wires are connected to the port? (high nibble or low nibble connection?)
it finally worked.
cristianp - thanks a lot for all your help. the lcd keeps displaying hello more than a single time. will try to figure that out. atleast its displaying something.
papunblg - the wires are connected to the high nibble.
.... the lcd keeps displaying hello more than a single time. will try to figure that out. atleast its displaying something.
You not have main loop, so your program will execute periodically. Add a dummy while loop at the end of your code:
		dis_data(data0[i]);
		i++;
        while (1);
@Project1
I am also working on the same project........
can u post me the code because I am unable to print the characters.........................
Thanking u..............
the code is there in the previous posts
Thanku for the reply................
Even i am using the same code.............previously
But the problem is when i am sending dis_cmd(0x28); for selecting two lines of the LCD, but it is showing only single line, and I saw that we have to send the dis_cmd(0x20) command as dis_cmd(0x02) instead. As a part of testing I tested entire connections and continuity of the circuit. Everything is fine..But the data I am sending is not displayed on the screen...........
I dont know what is the problem of the circuit at all..................
u have to give dis_cmd(0x20) only. it worked for me.
K. Thanku . I am getting the data on the display along with some garbage values which are displaying on the screen. may be I have to clear the data I sent after writing.....
