Zilog’s USB Smart Cable for Z8F1621
Gigillo74
Member level 2
Bologna - Italy
plese someone have schematics of DIY Zilog’s USB Smart Cable for Z8F1621 micro?
Thank You.
I havent heard of a DIY USB smart cable before.
Im not even sure if you can find the schematic of the original.. I tried before but failed.
i have used this z8f chip a few years back but i was using a DIY serial smart cable, not USB.
Since zilog's later versions of the ez8 supports only usb cable and not the serial, and i cant find the the schematic, I simply switched to using PIC
Bad move by Zilog
try this link
http://www.elab.ph/forum/index.php?topic=294.0
it is a zilog encore tutorial, but seems to be using a built-in serial smart cable
Thank You for your reply.
I've just find and see the Zilog Encore DIY 40-pin Board and it use a simple RS232 serial interface with DBG pin of microcontroller. I need to program Z16FMC series. Can i programm with serial smart cable?
Thanks
Your in luck.. looks like the Z16FMC Series supports 1-pin serial debug interface, so yes you can (probably) program it with serial smart cable..
I said 'probably' because you still have to check zilog's ZDS software if it is really supported.
