[SOLVED] Zener Diodes (clipping schematic) on a 50 ohm matched RF circuit
LandLack
Member level 3
Member level 3
Hi, I need to use two zener diodes on this configuration (https://en.wikipedia.org/wiki/Clipper_(electronics)) on the output of a 50 ohm matched RF circuit (1.4 GHz is the biggest signal frequency). Is there any issue? Do I need to match the diodes? How, and how much?
Can you give me an example?
Thanks,
Best Regards,
LandLack
The capacitance of the two diodes will be so high that they will act as a short for GHz frequencies.
Sorry.
Mandi
This makes the situation complicated; Thank you very much, you've avoided me a lot of problems.
Since I saw a circuit which used diodes as envelope detectors for the RF frequencies signals, I thought that zeners would also be ok. Can you tell me what parameter to see to judge diodes?
Also, do you have some ideas to clip RF signals?
Best Regards,
LandLack
