alternator voltage regulator schematic
Greetings! I just found this group a few days ago. Hello! I have been working on a voltage regulator for a motorcycle utilizing discreet components. The design is for an energized field coil, one side attached to B+ and the other to the circuit. The design criteria were:
Alternator: 200W/20A (energized field coil)
Battery: 12V/12AH Lead Acid Battery
Right now, the circuit delivers a maximum current of 1.2 Amps to the field coil. The voltage cut-off is set to 13.8V. The connection points are labeled in the schematic. The "STATOR" connection is connected to one leg of the 3-phase "WYE" circuit.
This circuit is still in the design stage. I wanted to submit the design for criticism, commentary and critique. Thank you.
Future goals: the ability to switch the circuit on and off via the ignition switch.
Right now the circuit draws around 20mA and under load, dissapates around 9W necessitating heat-sinking.
YAMAVR Parts List
R1 2.2k
R2 1.85k
R3 2.2k
R4 220k
R5 1.2k
R6 220k
R7 2.2k
R8 1k
C1 150n
C2 150n
C3 150n
C4 150n
C5 150n
D1 1N5408
D2 1N5408
T1 BC547
T2 BC547
T3 TIP3055T
DZ1 BZD23-C6V2
DZ2 BZV49C6V2
