dinesh106
- Joined
- Feb 15, 2013
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Kodumudi,Erode
- Activity points
- 1,333
Hi Frds,
Plz correct my error..
Giv me the idea for this r correct the error and send to my mail id : 54321.dinesh@gmail.com
Error in Xilinx:
Xst:528 - Multi-source in Unit <twomux> on signal <cout>
Program in VHDL:
TWOMUX:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity twomux is port
(a,b:in std_logic_vector(1 downto 0);
cin:in std_logic;
k
ut std_logic_vector(1 downto 0);
cout
ut std_logic);
end twomux;
architecture struct of twomux is
component twobitadd is port
cin:in std_logic;
s
cout
ut std_logic);
end component;
component twobitadd0 is port
cin:in std_logic;
s
cout
ut std_logic);
end component;
component muxtwo is
port(m: in std_logic_vector(1 downto 0);
n: in std_logic_vector(1 downto 0);
o: in std_logic;
cout : out std_logic_vector(1 downto 0));
end component;
signal s1,s2:std_logic_vector(1 downto 0);
begin
a1:twobitadd0 port map(a,b,'0',s1,cout);
a2:twobitadd port map(a,b,'1',s2,cout);
a3:muxtwo port map(s1,s2,cin,k);
end struct;
Sub Programs:
2bitadd0:
library ieee;
entity twobitadd0 is port
cin:in std_logic;
s
cout
ut std_logic);
end twobitadd0;
architecture struct of twobitadd0 is
component fulladder is port
(a,b,c:in std_logic;
s,c1
ut std_logic);
end component;
signal c1:std_logic;
begin
a1:fulladder port map(a(0),b(0),cin,s(0),c1);
a2:fulladder port map(a(1),b(1),c1,s(1),cout);
end struct;
2bitadd:
library ieee;
entity twobitadd is port
cin:in std_logic;
s
cout
ut std_logic);
end twobitadd;
architecture struct of twobitadd is
s,c1
ut std_logic);
end component;
begin
end struct;
Mux(2:1):
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity muxtwo is
o: in std_logic;
end muxtwo;
architecture mu of muxtwo is
begin
process(m,n,o)
begin
if o ='0' then cout<=m;
else
cout<=n;
end if;
end process;
end mu;
Error in Xilinx:
Program in VHDL:
TWOMUX:
library ieee;
cin:in std_logic;
k
cout
end twomux;
cin:in std_logic;
s
cout
end component;
cin:in std_logic;
s
cout
end component;
component muxtwo is
o: in std_logic;
end component;
begin
end struct;
Sub Programs:
2bitadd0:
library ieee;
cin:in std_logic;
s
cout
end twobitadd0;
s,c1
end component;
begin
end struct;
2bitadd:
library ieee;
cin:in std_logic;
s
cout
end twobitadd;
s,c1
end component;
begin
end struct;
Mux(2:1):
library IEEE;
entity muxtwo is
o: in std_logic;
end muxtwo;
begin
process(m,n,o)
begin
else
cout<=n;
end if;
end process;
end mu;
