failed to process bmm information
hi!
thanks.. i've try out ur method n the xmp fall under the top(test.v) successfully..
but wen i sythesize it.. wooh! alots of errors
* HDL Compilation *
Compiling verilog file "/ps2_keyboard.v" in library work
Compiling verilog file "MicroBlaze/hdl/microblaze.v" in library work
Module <ps2_keyboard_interface> compiled
Module <microblaze> compiled
Module <microblaze_0_wrapper> compiled
Module <mb_opb_wrapper> compiled
Module <debug_module_wrapper> compiled
Module <ilmb_wrapper> compiled
Module <dlmb_wrapper> compiled
Module <dlmb_cntlr_wrapper> compiled
Module <ilmb_cntlr_wrapper> compiled
Module <lmb_bram_wrapper> compiled
Module <sram_256kx32_wrapper> compiled
Module <sram_256kx32_util_bus_split_0_wrapper> compiled
Module <dcm_0_wrapper> compiled
Module <vga_0_wrapper> compiled
Compiling verilog file "/../test.v" in library work
Module <ps2_kbd_driver_0_wrapper> compiled
Module <top> compiled
No errors in compilation
Analysis of file <"top.prj"> succeeded.
ERROR:HierarchicalDesignC:18 - Partition:
ersistLoad: Failed to read Partition XUID. Partition not loaded.
ERROR:HierarchicalDesignC:60 - Failed to load partition 0 from "D:/VGA_testing/VGA_testing.ise". Partition not loaded.
ERROR:HierarchicalDesignC:62 - Could not find Partition for hierarchy node <>. HDProject not loaded.
FATAL_ERROR:Xst:hdlreadxcf.c:275:1.18 - Problem opening the IHDProject. Process will terminate. For more information on this error, please consult the Answers Database or open a WebCase with this project attached at
https://www.xilinx.com/support.
ERROR:HierarchicalDesignC:60 - Failed to load partition 0 from "D:\VGA_testing\VGA_testing.ise". Partition not loaded.
WARNING: The ngc files for partitions could not be added.
Process "Synthesize" failed
BIG HEADACHE! any idea wads tt?
