bouvett2
Newbie level 5
Hi all,
I am currently doing a very simple beginners project via Xilinx XPS software which involves a microblaze on a SPartan3e starter board by digilent. I used the BSB wizard so to create the system which only used the on board leds and switches.
When I finish the wizard, I go on Hardware -> Generate Bitstream... and the following error goes on:
ERRORortability:90 - Command line error: Unexpected argument[10] "Files" found.
Does anybody have an idea why this is occurring? I Have searched the web, but I only found similar errors... such errors seem to be generated from the software as such. I tried restarting the PC and even re-installing the program but the error persists.
This is the exact error:
Any help would do.
Thanks for your time.
regards,
bouvett2
"Creating system netlist for hardware specification.."
platgen -p xc3s500efg320-4 -lang vhdl -intstyle default -lp D:/Xilinx/13.4/ISE_DS/Board Support Files (EMAN) -lp D:/Xilinx/13.4/ISE_DS/EDK/board/Xilinx/boards -msg __xps/ise/xmsgprops.lst system.mhs
Release 13.4 - platgen Xilinx EDK 13.4 Build EDK_O.87xd
(nt64)
Copyright (c) 1995-2011 Xilinx, Inc. All rights reserved.
Usage: platgen [-v] [-lang verilog|vhdl] {-lp <library_path>} [-log
<logfile[.log]>] [-od <output_dir>] [-p <partname>] [-st ||||xst|none] [-ti
<instname>] [-tm <top_module>] [-toplevel yes|no] [-parallel yes|no]
<infile[.mhs]>
Display Options:
-h
Help -- just display this message and quit application.
-help
-v
Version - Display version and quit application.
Options:
-f <filename>
Read command line arguments and options from file.
-lang verilog|vhdl
HDL language output.
Default: vhdl
-log <logfile[.log]>
Specify log file.
Default: platgen.log
-lp <library_path>
Add <library_path> to the list of IP search directories.
-od <output_dir>
Output directory path.
Default: .
-p <partname>
Use specified part type to implement the design.
-st xst|none
Generate synthesis project files.
Default: xst
Deprecated.
-ti <instname>
Top-level instance name.
-tm <top_module>
Name top-level module as desired.
-toplevel yes|no
Input design represents a whole design or a level of hierarchy.
Default: yes
-parallel yes|no
Invokes parallel synthesis feature.
Default : no
Valid architectures are:
ERROR:Portability:90 - Command line error: Unexpected argument[10] "Files"
found.
aartix7
artix7
artix7l
aspartan3
aspartan3a
aspartan3adsp
aspartan3e
aspartan6
kintex7
kintex7l
qrvirtex4
qspartan6
qspartan6l
qvirtex4
qvirtex5
qvirtex6
qvirtex6l
spartan3
spartan3a
spartan3adsp
spartan3e
spartan6
spartan6l
virtex4
virtex5
virtex6
virtex6l
virtex7
virtex7l
zynq
"Running synthesis..."
cd synthesis & synthesis.cmd
The system cannot find the path specified.
'synthesis.cmd' is not recognized as an internal or external command,
operable program or batch file.
make: *** [implementation/system.ngc] Error 1
Done!
Any help would do.
regards,
bouvett2
