rfsweden
Newbie level 1
I'm using a Xilinx ML403, Virtex4 board.
I have:
PowerPC system that works fine alone.
Userlogic that works fine alone.
My problems is that I need to run both these modules in parallel, at the same chip.
I have tried to simply instansiate the Userlogic in my "system_stub.vhd" file
If you are familiar to EDK and ISE you should know what I'm talking about.
Anyways, I have to share the sys_clk_pin_IBUFG between the userlogic
and the PowerPC system and this is the cause of the problem.
Because when I do this, the userlogic runs fine, but the PowerPC system don't
Any ideas why this happens?
My thought is that I cannot instansiate the userlogic in the system_stub.vhd
Maby this file needs to be "clean"
But how could I instansiate it otherwise?
I have:
