Xilinx VIRTEX II pro: ug024
voho
Full Member level 2
Nador City
Rocket IO sheet 33 of ug024.
How i can Attribute Defaut Values: GT_FIBRE_CHAN in vhdl code.
begin
ALIGN_COMMA_MSB<=false;
TX_PREEMPHASIS<=0;
end;
Thank's in advance
elektrom
Full Member level 2
It's not the attribute. It's a type of transceiver. You can use Architecuture Wizard to generate the component in VHDL. Such as..
component GT_FIBRE_CHAN_2
generic(
CLK_COR_INSERT_IDLE_FLAG : boolean := FALSE;
CLK_COR_KEEP_IDLE : boolean := FALSE;
CLK_COR_REPEAT_WAIT : integer := 2;
REF_CLK_V_SEL : integer := 0;
RX_CRC_USE : boolean := FALSE;
RX_LOS_INVALID_INCR : integer := 1;
RX_LOS_THRESHOLD : integer := 4;
RX_LOSS_OF_SYNC_FSM : boolean := TRUE;
SERDES_10B : boolean := FALSE;
TERMINATION_IMP : integer := 50;
TX_CRC_FORCE_VALUE : bit_vector := "11010110";
TX_CRC_USE : boolean := FALSE;
TX_DIFF_CTRL : integer := 500;
TX_PREEMPHASIS : integer := 0
port (
voho
Full Member level 2
Nador City
Hi elektrom and everybody :sm5:
Thank's for your help.
What do you do about the other signal. :idea:
The other signal is not necessary :?:
COMPONENT GT_CUSTOM
generic (
ALIGN_COMMA_MSB : BOOLEAN := FALSE ;
CHAN_BOND_LIMIT : INTEGER := 1 ;
CHAN_BOND_MODE : string := "OFF" ;
CHAN_BOND_OFFSET : INTEGER := 0 ;
CHAN_BOND_ONE_SHOT : BOOLEAN := TRUE ;
CHAN_BOND_SEQ_1_1 : std_logic_vector(10 downto
0) := "00000000000" ;
CHAN_BOND_SEQ_2_4 : std_logic_vector(10 downto
CHAN_BOND_SEQ_2_USE : BOOLEAN := FALSE ;
CHAN_BOND_SEQ_LEN : INTEGER := 1 ;
CHAN_BOND_WAIT : INTEGER := 7 ;
CLK_CORRECT_USE : BOOLEAN := TRUE ;
CLK_COR_SEQ_1_1 : std_logic_vector(10 downto
0) := "00110111100" ;
CRC_FORMAT : string := "FIBRE_CHAN" ;
port (
Please see https://www.xilinx.com/bvdocs/appnotes/xapp660.zip
Thank's in advance 8)
regards :eek:
voho
Full Member level 2
Nador City
Hi everybody,
I have a type of transceiver: coaxial cable. I use Architecuture Wizard to generate the component in VHDL. BUT in select transceiver he purpose:
Aurora
Custom
Ethernet
Fibre Chanel
Infiniband
XAUI
For coaxial cable is XAUI or ..... :?: :?: :?: :?: :?:
Regards
voho
Full Member level 2
Nador City
Hi
More info my electric diagram about coaxial cable
Thank's in advance
yerics
Member level 1
Beijing&#65292;China
Maybe you can select GT_CUSTOM to custom your coaxial cable.
of cause , you can refer with XAUI
