Xilinx usb II platform cable driver centos 7.3/vivado 16.3
hi,
[root@localhost ~]# cd /opt/Xilinx/Vivado/2016.3/data/xicom/cable_drivers/lin64/install_script/install_drivers
[root@localhost install_drivers]# ./install_drivers
INFO: Installing cable drivers.
INFO: Script name = ./install_drivers
INFO: HostName = localhost.localdomain
INFO: Current working dir = /opt/Xilinx/Vivado/2016.3/data/xicom/cable_drivers/lin64/install_script/install_drivers
INFO: Kernel version = 3.10.0-693.el7.x86_64.
INFO: Arch = x86_64.
USB udev file exists and will not be updated.
--File /etc/udev/rules.d/52-xilinx-pcusb.rules exists.
--File /etc/udev/rules.d/52-xilinx-pcusb.rules version = 0002
--File 52-xilinx-pcusb.rules exists.
--File 52-xilinx-pcusb.rules version = 0002
--File 52-xilinx-pcusb.rules is already updated.
INFO: Digilent Return code = 0
INFO: Xilinx Return code = 0
INFO: Return code = 0
INFO: Driver installation successful.
CRITICAL WARNING: Cable(s) on the system must be unplugged then plugged back in order for the driver scripts to update the cables.
Although driver installation successful it dioesn't work / not show even power. Don't know what's wrong. I am new to linux. Any help?
with lsusb it shown already though:
[root@localhost ~]# lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0461:4e04 Primax Electronics, Ltd
Bus 001 Device 010: ID 03fd:0013 Xilinx, Inc.
Bus 001 Device 002: ID 17ef:6019 Lenovo
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
[root@localhost ~]#
