8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
| `timescale 1ns / 1ps
// Company:
// Engineer:
// Create Date: 08/07/2018 10:11:10 PM
// Design Name:
// Module Name: datain
// Project Name:
// Target Devices:
// Tool Versions:
// Description:
// Dependencies:
// Revision:
// Revision 0.01 - File Created
// Additional Comments:
module datain(
parameter CLOCK_PERIOD=100;
parameter width=10;
parameter frameSize=400;
reg clk,reset,val;
reg [0:2*width-1] windowOut;
reg donewin;
reg last;
reg [19:0] m_axis_data_tdata_re;
reg [19:0] m_axis_data_tdata_im;
wire s_axis_config_tready;
reg [19:0]povey[0:399];
reg [7:0] s_axis_config_tdata;
wire s_axis_data_tready;
integer i;
wire m_axis_data_tready ;
wire event_frame_started;
wire event_tlast_unexpected;
wire event_tlast_missing;
wire event_status_channel_halt;
wire event_data_in_channel_halt ;
wire event_data_out_channel_halt;
wire m_axis_data_tvalid;
wire [47:0] m_axis_data_tdata;
wire m_axis_data_tlast;
integer file;
integer file1;
integer file3;
integer stat;
initial
begin
i=0;
clk=0;
reset=0;
donewin =0;
last =0;
windowOut = 20'b0; //20=2*width
file3= $fopen("in.mem","r");
while (! $feof(file3))
begin
stat=$fscanf(file3,"%d",povey[i]);
i=i+1;
end
$fclose(file3);
#10 i=0;
#20 reset<=1;
#80 reset <=0;
val<=1;
s_axis_config_tdata <=8'b0;
file= $fopen("outre.txt","w");
file1= $fopen("outim.txt","w");
end
always @(posedge clk)
begin
if(val)
begin
windowOut<=povey[i];
i<=i+1;
donewin<=1;
last <=0;
end
end
begin
if((i>399) && (i <512))
begin
windowOut<=0;
i<=i+1;
donewin<=1;
last<=0;
val<=0;
end
if(i==511)
begin
i <=0;
last <=1;
end
if(last==1) donewin<=0;
end
xfft_0 uut (
.aclk(clk),
.aresetn(~reset),
.s_axis_config_tvalid(donewin),
.s_axis_config_tready(s_axis_config_tready),
.s_axis_config_tdata(s_axis_config_tdata),
.s_axis_data_tvalid(donewin),
.s_axis_data_tready(s_axis_data_tready),
.s_axis_data_tdata(windowOut),
.s_axis_data_tlast(last),
.m_axis_data_tvalid(m_axis_data_tvalid),
.m_axis_data_tready(m_axis_data_tready),
.m_axis_data_tdata(m_axis_data_tdata),
.m_axis_data_tlast(m_axis_data_tlast),
.event_frame_started(event_frame_started),
.event_tlast_unexpected(event_tlast_unexpected),
.event_tlast_missing(event_tlast_missing),
.event_status_channel_halt(event_status_channel_halt),
.event_data_in_channel_halt(event_data_in_channel_halt),
.event_data_out_channel_halt(event_data_out_channel_halt)
begin
if(m_axis_data_tvalid==1)
begin
m_axis_data_tdata_re <= m_axis_data_tdata[19:0];
$fwrite(file,m_axis_data_tdata[19:0]);
m_axis_data_tdata_im <= m_axis_data_tdata[43:24];
$fwrite(file,m_axis_data_tdata[43:24]);
end
end
always #(CLOCK_PERIOD/2) clk <= ~clk;
endmodule |
