1. No, the transceivers are CML hard IP transmit and receive multi-gigabit serial links (GTX/GTH/GTP, etc). SERDES is just a serial/deseralizer. Both the C2C and the transceivers use SERDES but they are different hard IP. The ISERDES/OSERDES blocks are in the selectmap I/O.
2. Chip-to-chip uses AXI as its protocol and is implemented as a source synchronous interface. The transceivers uses 8b10b or 64b66b encoding to achieve both DC balancing and clock recovery (I'm pretty sure you can use the coregenerator to produce a wrapper that interfaces the transceivers to AXI).
For 7 Series parts.
Refer to the "SelectIO Logic Resource" section of UG471 and UG476 for information on the GTX/GTH transceivers.
Aurora is not source synchronous, it uses the CML transceivers and recovers the transmit clock at the receiver from the data, hence the need for 8b10b or 64b/66b encoding to ensure enough transitions occur to allow clock recovery and keep the DC level constant.
For 3.125Gbps aurora you only need a single differential pair (2 wires). For a source synchronous serial interface you need at least a clock and a data connection (if differential then that means four wires).
Guessing based on other benefits of encoding the data....besidss clock recovery 8b10b means you have 4x the number of symbols, and 8b10b was designed such that any single bit flip produces an invalid symbol (instant error detection). Also there are extra K-codes for things like idle, start, stop, etc. Whick are mighty handy for packet based protocols such as AXI.
I'm somewhat assuming that it was convienent to use 8b10b than create something new. I'd have to look into it to determine how accurate my guess is.
It is interesting to note that you can use the Aurora PHY for the Chip2Chip interface...see Figure 1-1 and Figure 3-2 in PG067. I guess taking advantage of the transceivers to implement a version of the Chip2Chip interface is one of the options besides using the SelectIO PHY. I now see that the 8b10b references you are seeing are due to the Aurora core.
Well what I stated in #10 depends on your requirements (both bandwidth and address architecture). Aurora with bonded channels will have significantly more bandwidth with way less pins than a C2C using SelectIO. If you use C2C with Aurora PHY then you're basically just avoiding having to build a non-streaming interface for Aurora's streaming AXI yourself. If you have latency requirements the C2C using SelectIO has the minimum latency of the two PHY.
You should probably read PG067 as all of this is from there. I actually had to browse that document (again) as I haven't looked at it for quite some time.
